What is the stock 07 bar height?
2 replies to this topic
  • 700MX
Posted December 11, 2006 - 01:24 PM
Does anyone know the stock 07 bar height mm spec is, and maybe pullback mm too.....so I can compare to others using a chart. I was wondering if the cr high bend is still higher than stock
Thanks
700
Posted December 11, 2006 - 02:09 PM
The '06 bar was very similar to the Pro Taper YZ High (84mm) visually, although I've seen it said that the height was actually more like 80, It depends a lot on how they're measured. The '07 bars are 8mm higher. I don't know if that helps you at all, but it's what I know about it.
  • WFOracer
Posted December 11, 2006 - 02:24 PM
I saw that dirt bike mag called them a CR-high bend.
