bent gear shift lever
4 replies to this topic
  • Henry
Posted January 16, 2001 - 05:46 PM
Hi all, any chance of getting it back into shape?(by knocking)
Will it break?
How much is a new lever cost?
1998 WR400F
'98 WR400F, YZ timed, main:180, pilot:48, DVR needle 4th clip from top,
snorkel removed, YZ tank/seat combo, YZ front no.plate/rear fender,
DSP Ti exhaust system, Brembo front brake,steel braided hose, EZ clutch adjust perch,
Stroker billet rear brake reservoir
  • RAZOR
Posted January 16, 2001 - 06:10 PM
Heat your shifter with a torch- not too much though, then using vise-grips, bend it back to its correct position- VERY SLOWLY!!!!!
You may have to repeat heating and bending MANY times. Good Luck!
  • Henry
Posted January 17, 2001 - 01:03 AM
hey Razor!!
thanks for the help! :)
  • Buck
Posted January 19, 2001 - 07:52 AM
Moose steel shifter costs only about 30 bucks. Stock is something like 70 bucks.
  • Bill
Posted January 19, 2001 - 08:23 AM
Be careful with steel shifters. Yes, they are strong, but you may break the shift arm into the case, rather than the shifter itself. Just something to consider.
Bill
86TT225, 99WR, WR timing, throttle stop trimmed, air box lid removed, White Bros head pipe, silencer and air filter. Odometer and headlight removed. Moose hand and mud guards. YZ stock tank and IMS seat. Renthal Jimmy Button "highs" and Renthal Soft half waffle grips. AMA, SETRA.
