Designing the ultimate engine! Help me!
9 replies to this topic
  • xr650l bum
Posted December 08, 2006 - 07:50 PM
I would like to create the ultimate mod for my xr650l. A new Heart!! I have an extra complete 650l motor, and an extra complete lower end/trans from a 600r. I am going to transplant the trans/kickstart into the 650l, but while im there(the mechanic that is) I would like to mod the engine, bore, cam what have you. I would like your advice on what parts to use. I would like to use pump gas, not racing fuel. I am also looking for a shop near So Cal /San Diego to help me in this venture. Any help, advice would be greatly appreciated. It would also be nice to document what is being done so that others can have an easier time doing the ultimate mod!!!:worthy: :D :prof: :bonk:
  • cbaranski
Posted December 09, 2006 - 05:02 AM
Sounds like that will be a cool combo.
  • perry5150
Posted December 09, 2006 - 09:40 PM
keep Me Posted Man I Want Some More Power Outta My 650l Also
  • Wheels up
Posted December 10, 2006 - 08:08 AM
WEBCAM camshaft (213/202 grind). Hard welded rockers. 102 MM Wiseco piston. Carillo connecting rod. Barnett clutch pack with stiff springs. Keihin 41MM FCR carb. Custom airbox. Good valves and valve springs. Full exhaust.
Have someone port and polish your cylinder head.
This combo would have a little hotter running temp but if you wanted a beast you would have one.
  • simon@vic
Posted December 10, 2006 - 09:41 AM
im assuiming your ditching the starter and batterie too right?
  • xr650l bum
Posted December 10, 2006 - 11:10 AM
Would that not just be a 600r? I have a complete 600r engine as well as the650l! I like my L and would rather modify it than mod the r with electric start. Changing the L should be mechanical, while changing the r would require a bunch of electrical garb that I really dont want to mess with!
  • wheelnut46
Posted December 10, 2006 - 03:20 PM
I'm assuming your ditching the starter and battery too right?
Why not have them both? That would be the best.
Adding a 6th gear would be the ultimate.
  • rebelventurer
Posted December 10, 2006 - 03:38 PM
Try to contact TT member rideaide, or email at rideaide@hotmail.com for shop I am assuming mechanical and machine work is what you are looking for.
I hear the HRC camshaft, stainless valves with the kibblewhite springs, forged rockers, new camchain, followers, tensioner, etc... work welll and if you port leave the intake side alone and just clean up the exhaust side. Also try the JE piston in a low compression version 10 to 1 up to 102.4 mm with stock rod and bottom end.
  • Jon-D
Posted December 10, 2006 - 04:20 PM
Travis 37 (TT member) has a shop in Pasadena and does this type of work. He has a ton of experience doing engine modifications and really loves the jobs where he gets to do something that requires a little more out of the box thinking. He made some modifications to the motor in my KTM and that thing really hauls the mail compared to the stocker.
  • simon@vic
Posted December 11, 2006 - 10:42 AM
injection, 70hp, 1/2 the weight of a 600/650l engine!
  • 22 replies
  • Hot  28 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
  • Hot  148 replies
Honda XR650L 2016
  • 0 reviews
