XR650R Help?!?!?!?!
3 replies to this topic
  • Itchy
Posted December 06, 2006 - 10:51 PM
I'm looking for any help I can get with an 02 XR650R:excuseme: :worthy:
I took my carb out/apart to clean it and I've got a hose that I can't
find a home for. I can't find a scrap of info on and no place "with in
reach" for it to go. The hose is on the clutch side of the bike just
above and forward of the ACV.
The bike will start and run with the hose capped but once off idle it
falls on it's face. I picked the bike up used and on the orig tires
w/over 50% tread left so the bike has not been ridden just laid down to
the tune of a left radiator <that does not leak. Other than some
scratches and dented radiator the bikes like brand new for an 02. Any
help would be greatful!!
Thanx in advance
Russ:banghead: :D :prof:
  • nickreal
Posted December 06, 2006 - 11:13 PM
I'm not much of a mechanic but if you take a picture of it I can compare it to my xr650r and see if I can tell you where it goes.
Rick
  • Beelzeboss
Posted December 07, 2006 - 06:44 AM
Sounds like one of the ventilation/drainage hoses? Those usually dont go anywhere,just point them downwards:thumbsup:
  • Itchy
Posted December 07, 2006 - 05:17 PM
there is a cover on the carb on the clutch side of the bike. The cover faces you the hose faces you just above it and a little left the other hose runs strait up and is closer to the intake.
  • Hot  60 replies
  • 22 replies
  • 4 replies
Washington
  • Hot  32 replies
  • 9 replies
