Hard Time Starting CR250
13 replies to this topic
  • 250Nasty
Posted December 06, 2006 - 05:28 PM
Well, i have a honda 2000 honda cr250 and it dosent start two swell, when its cold, could this be me needing to do a top end, the plug is only about one ride old, and i dont know why it is doing this, could any body help that has a cr250, could it be cause its the winter and just harder to start?
  • kuritaro9
Posted December 06, 2006 - 05:42 PM
its probably a little lean...try the 2 stroke lean to get it fired up...
  • stonedigity
Posted December 06, 2006 - 05:44 PM
Your bike may be getting tired...who knows. Hard starting is also often the result of worn or chipped reeds. Have a quick look and be sure the tips aren't chipped or cracked, and that the lie down flat against the stops as well. Good luck:thumbsup:
  • 808hondacrguy
Posted December 06, 2006 - 08:05 PM
I had that problem with my 01 and had to put in a larger pilot jet .:worthy:
  • Virtus
Posted December 06, 2006 - 08:20 PM
My quick guess: When the temperature drops, like it does in Delaware this time of year, the air charge in your engine gets more dense. With the same fuel charge, your bike will run lean. Fiddle with your air screw. If that doesn’t work, rejet. It’s cheap and satisfying when your bike runs like crazy.
  • XR250rdr
Posted December 06, 2006 - 08:36 PM
The bike should start with the choke on even if its kinda lean. If turning in the air screw doesnt make much difference, I'd bet on worn reeds.
  • sonobob
Posted December 07, 2006 - 06:19 AM
Which carb does that bike have???
Surely they didn't carry the P(uke)J(et) unit that far down the production line...talk about a quirky, high-maintenance carb...I've dated blonde's that required less attention.
  • skipn8r
Posted December 07, 2006 - 07:10 AM
'00 was the last year for the PWK.
  • 250Nasty
Posted December 07, 2006 - 07:59 AM
thank you kind sirs, how hard is it to check the reeds, i have never had any experience with reeds so i dont really have a clue
thanks
  • 250Nasty
Posted December 07, 2006 - 08:03 AM
o, and i do have the clymers manual for my bike, so it probally will tell me in there, but what i was really wondering is if it will take a while, or if it is somthing i can do in a relativley short amount of time, and how i would go about gaining access to teh reeds
  • sonobob
Posted December 07, 2006 - 08:37 AM
Like any 'maiden voyage' into an unfamiliar task, the first time doing it will always take longer, but this one isn't bad...take your time, keep your manual right there with you, keeping one eye on the instructions. It would also be a good idea to read through the procedure before shaking the first wrench...simply put, it's basically nothing more than pulling the carb and the cylinder-side intake boot, after thoroughly cleaning all the surrounding area on the bike. The reed cage will be right there. I would suggest that you go ahead and pick up a new set of reeds, loctite and sealant to have on hand and at the ready. Be really careful not to slop that stuff around when you put it all back together. (And I'm sure it will mention this in your manual...but just in case you miss it, the sealant has to be impervious to gasoline)
  • 250Nasty
Posted December 07, 2006 - 04:06 PM
thanks a lot!
  • sonobob
Posted December 07, 2006 - 04:38 PM
No prob...just payin' it forward...before long, you'll be doing the same...
  • 250Nasty
Posted December 07, 2006 - 07:04 PM
yea, i have done it to a few people allready, lol, thanks again
New to the forum. Question regarding cylinder scoring and break in by BlakeCR
Dirt Bike   Make / Model Specific   Honda   Honda 2-Stroke
  • Hot  50 replies
optimum lowend torque sprocket size cr80r by ericinkmonster
  • 17 replies
What did you do with your CR today? by thetinkerer
  • Hot  69 replies
2006 CR125 Startup Help by Will I Am
  • 13 replies
CR125 High Revving on Start Up by Will I Am
  • Hot  28 replies
