XR600 early front axle/wheel with 94 forks?
2 replies to this topic
  • jpoore
Posted December 06, 2006 - 01:27 PM
I have a 86 XR600R and plan to put some 94 forks on. I've read that the later models have a bigger axle that effects the hub, but I haven't read whether the axle to fork mounting dimentions are changed.
Do I need to find a later model axle and change the bearings in my hub, or can I use my early axle with these forks?
Thanks.
JP
  • cbaranski
Posted December 06, 2006 - 04:40 PM
Honda went to a bigger front axle in 93. You might be able to get the newer bearings for your older wheel? Not for sure though.
  • Jeff@TheQuadShop
Posted December 06, 2006 - 08:04 PM
You will need to get the later model bearings/inner spacer and axle.
