xr650r - does a BD Dual Sport kit restrict airflow
6 replies to this topic
  • fastforward
Posted December 06, 2006 - 11:06 AM
Does a Baja Designs Dual Sport kit battery, rectifier, and wiring on top of air box restrict airflow enough to require the side cover to be opened on a stock motor?
  • Mudshark
Posted December 06, 2006 - 12:48 PM
Not too sure which kit you are referring to here.... mine all mounts up
behind the front number plate above the headlight.
So, no it does not cause any issues if mounted there.
Can you post a link to the kit in question? thanks.
  • MindBlower
Posted December 06, 2006 - 12:56 PM
you have the quick release. The standard kit mounts as he said.
  • pigryder
Posted December 06, 2006 - 01:03 PM
NO :worthy:
  • adam574
Posted December 06, 2006 - 01:24 PM
if it was up to me... actually it was up to me and i bought the quick release kit... definately an all around better package. if i remember right it was only an extra 100 bucks.
  • Maroast
Posted December 06, 2006 - 01:31 PM
Have you had the seat off an xr650r and seen how/where thoes components mount? I can see no way that they would interfere with air flow into the intake..... so no, dont worry aboot it.
just to be safe though (better safe than sorry), drill out your side pannel, install a high flow filter, new can/ high flow header, hotcam...um, maybe a pumper carb....this should offset the added weight and such of the BD kit :worthy:
  • Mudshark
Posted December 06, 2006 - 01:33 PM
Oh, okay, thanks. I guess you could fit it all on top of the airbox without
causing any problems... if you're using the regular little "dry cell" battery pack. :worthy:
  • Hot  35 replies
  • 4 replies
  • 17 replies
  • Hot  186 replies
Honda XR650L 2016
  • 0 reviews
