Paddle Tire Question
7 replies to this topic
  • Dan Turner
Posted December 06, 2006 - 10:34 AM
I finally found a 17" paddle for my 87 XR600R. Got if off ebay....It's a Skat -Trak tire with Hooker paddles. When I got the tire, which is brand new, I realized it was made from a street bike tire that is tubelss. It has the speed rating on it that say 150MPH!!:worthy:
Anyway...the question is, will running a tube in a tubeless tire be a probelm??
-Dan
  • goblin127
Posted December 06, 2006 - 10:41 AM
I have run a tube in a tubless tire before,but it was on a street bike with alloy wheels.
  • Dan Turner
Posted December 06, 2006 - 10:45 AM
Should I run a higher pressure to eliminate some friction and heat?
-Dan
  • eastreich
Posted December 06, 2006 - 11:25 AM
Yes, I would run higher air pressure. I usually run my Skat-Trak paddle at around 16-18 psi (as opposed to the 12-13 normally). I also use a lot of baby powder and the smoothest tube (Michelin or Bridgestone, no cheap FLY tubes here) that I can find to help keep tire temperature down.
Runnig a tube in a tubless tire is not a problem. The tubeless carcass that Skat-Trak used will be stiffer, and with the paddles stiffer yet, so it will probabaly be a real b#$%h to mount.
I'm sure that in this day and age, the only carcasses that Skat-Trak can get to vulcanize the paddles on are street bike tires. OEM dual sport rubber that may be found in a 17" is too narrow of a tire to use for the paddles.
  • Dan Turner
Posted December 06, 2006 - 12:32 PM
Thanks for the heads up.
-Dan
  • Dan Turner
Posted December 06, 2006 - 12:40 PM
It was tough to stretch over the rim, but the wider carcass made it a bunch easier to get the valve stem and rim lock on. I hate changing rear tires.
-Dan
  • eastreich
Posted December 06, 2006 - 03:04 PM
-Dan
The only nice thing about putting on a paddle tire. It's easy to get the tube in.
If I did dunes a lot (instead of once or twice a year), I would definitely get a spare rear wheel just to keep the paddle tire on.
  • ljspop
Posted December 06, 2006 - 05:21 PM
I'm considering getting a spare wheel for this reason. Anyone have suggestions on where to or not to get one?
  • 3 replies
  • Hot  148 replies
  • 2 replies
  • Hot  35 replies
  • Hot  60 replies
