Zip-Ty magnetic plug workin hard!
13 replies to this topic
  • wayneoXCF
Posted December 29, 2001 - 12:43 PM
This thing might be the best $15 I spent on my bike. It catches all of those shavings, and is always workin hard for me. I have about 800 miles, and Im still getting little pieces on the magnet. I dont even want to think about where they might be if not for that plug. Gotta love it. :)
  • Ike
Posted December 30, 2001 - 07:47 AM
Wayneo I also have a Zip-Ty magnetic drain plug and without a doubt it is the best 15$ I could have ever invested on my bike.
:) Great Post
Ike of Colo
WRockomotive
WR426 2001 A few free mods.
TTR125L
PW50
  • AZWR400
Posted December 31, 2001 - 10:59 PM
Wayno, where to score a zip-ty drain plug? Also searching for a YZ tank and seat. Thanks
  • wayneoXCF
Posted December 31, 2001 - 11:16 AM
AZ-
Go to Zip-Ty Racing for the plug. As far as your seat /tank, if you want used, I would suggest going over to the YZ forum, and asking around in there. I think you can use a 98 and up tank that will bolt right on. All the hardware worked on mine.
If your looking for a new tank/seat, alot of guys go for the Clarke tank, and an SDG complete seat. The seat is around $70, while the tank is ( I think), close to $175. I actually saw an IMS 3.3 gal tank on eBay a few weeks ago. Good luck!
  • Scott_in_KC
Posted December 31, 2001 - 01:45 PM
Wayneo, How'zit brother! Finally recovering from a horrible hard drive failure over the weekend and just now getting back online...ROYAL PAIN IN THE A$$!!!
I think the metal shavings will continue forever, I believe most of it after a while is metalic clutch plate material. My Husaberg was 5 years old and still had a nice coating of shavings each change.
Have a good new year.
Late.
  • yzernie
Posted December 31, 2001 - 04:48 PM
The thing I like about it is that it will catch pieces small enough to get through the filter. I have used Ty's plugs for years and won't use any other kind.
http://www.ziptyracing.com
Ernie
  • SFO
Posted January 10, 2002 - 05:35 AM
Make sure you use the stock thickness sealing washer on your ty plug.
The first ones he did had a too thick washer that encouraged stripping of the cases.
  • MOmilkman
Posted January 10, 2002 - 08:29 AM
When I bought my bike new, I tried one of those magnetic plugs made by Moose and for some reason it wouldnt thread into the case. Anyone else ever had this problem?
It was for a YZ250 but they told me it would work on my bike. I checked Dennis Kirk and they said the same thing.
Hmmm, might have to try this plug.
[ January 10, 2002: Message edited by: MOmilkman ]
  • Jason_in_KC
Posted January 10, 2002 - 08:44 AM
Hey Milkman..fellow Missourian here..I have the Moose magnetic drain plug..bolted right in like factory..this thing has a nice big 14mm head on it that a socket can actually grab..that stocker head rounded off real quick!
  • Scott_in_KC
Posted January 10, 2002 - 06:51 PM
Jason,
You might try using a metric wrench instead of vise grips...bolts last longer. :)
  • AZWR426
Posted January 12, 2002 - 03:40 PM
I was at the Yamaha dealer the other day and the parts guy said Yamaha made a magnetic drain plug. Do they? And do they work as good as Zip-Ty Racings?
  • wayneoXCF
Posted January 13, 2002 - 05:09 AM
Im sure if Yamaha is selling a plug, its prob a little more expensive, IMO. The Zip-Ty picks up a pound or so.
  • crazyadam
Posted January 13, 2002 - 07:22 AM
If anybody wanys one, or both of my moose "mag" plugs, you can have them. Neither one that I have will stick to my fridge, no less hold any chunks on it. The zip-ty plug will hold a complete cam, so I know it will hold any small chunks floating in the case. Fortunatly I haven't seen anything very big, but when Ty chipped a gear he still finished... Best 15$ for sure!! :)
  • HoustonYZF
Posted January 13, 2002 - 12:08 PM
I had a Zip Ty plug and loved it...had to recently replace it though, the threads are pretty soft and easy to over torque. I cranked the plug in one day and instead of getting tighter it kept gettting easier to turn...I had destroyed the threads, it still worked, but soon began to leak so I put the stocker back in and ordered another...lesson learned: use a torque wrench on these soft aluminum bolts!
