HotCam in my 650L
5 replies to this topic
  • sgifford
Posted December 05, 2006 - 09:00 PM
I had to replace my stock camshaft, so I went with a HotCam. My top-end was very noisy, so I checked and found the camshaft and rocker arms were in need of replacement. While in there, I also replaced the cam chain and tensioner.
Unfortunately, after putting it back together and starting it up, the top-end is still very noisy. Too noisy. The noise is definitely top-end. (I've checked and rechecked the valves.)
All I can think of at this point is noise from one or more worn valve trains. I don't hear any clicking when I rotate the engine by hand, only when it's running. What could be noisy in the valve train? A broken spring?
Back into the engine again...
Seldon
  • flametrain
Posted December 12, 2006 - 07:28 PM
hello there..
are you sure your cam chain is adjusted correctly...
  • porterdog
Posted December 14, 2006 - 01:00 PM
Does the L have an auto-decompression dealie on it? Those have a rep for being loud at idle...
  • rebelventurer
Posted December 14, 2006 - 03:07 PM
Could be a number of things, valve guides, decompression actuator, cam chain. Did you pull the head? valve seats, valves could be worn and the culprit of excess noise? :thumbsup:
  • Shawn_Mc
Posted December 14, 2006 - 03:57 PM
For some reason the Hotcam profiles generate more noise too. I know everybody thats put them in a CRF says the same thing. You may want to ask that question at HotCams.
  • valvesrule
Posted April 26, 2009 - 11:46 PM
Just put mine in and it's just as quiet as the stocker.
  • 22 replies
  • 3 replies
Washington
  • Hot  32 replies
  • 17 replies
  • 9 replies
