Wheel lacing...any tricks to it?
6 replies to this topic
  • YZ426F Rider
Posted December 05, 2006 - 12:11 PM
I think I am going to change over to an 18" rear wheel for better protection in the rocks and also so I can run a trials tire on the rear once in awhile. Might even switch over to black rims :worthy:
Has anybody laced up wheels before? Are there any special tips or tricks to it? How about spokes...recommendations?
  • 520Roost
Posted December 05, 2006 - 12:31 PM
i have done some before not to hard at all the spokes come with directions ,its just a little tricky to get the wheel true.good luck.
  • WEAL
Posted December 05, 2006 - 12:45 PM
Start with the innermost spokes on both sides of the hub and lace them to the rim. That way you get no problems with fitting the outer spokes. On each side of the hub you have every second spoke go the same direction - on the rim its every fourth hole. This will help you as a firsttimer. Take a look at the front wheel - the principle is always the same - no matter what wheel it is - except the BMw wheels on heavy twins.
Good luck
Posted December 05, 2006 - 01:56 PM
Look this over:
http://www.dansmc.com/spokewheels.htm
Once you've installed all the spokes and are ready to start tightening, use the exposed threads under the spoke nipple as a guide to getting them all run down uniformly. If the threads disappear before the spokes draw up, keep going from that point a half turn at a time until they're all snug. If you encounter a tight one before the wheel is tight, bypass it. It may turn up as loose later on. Once they are all snug, and the wheel is reasonably still round/flat, proceed to run them down to the recommended torque, truing as you go.
  • KJ790
Posted December 05, 2006 - 03:04 PM
Here is a quick little video that might help:
http://www.vitalmx.c...album=866&pos=0
  • torqueme
Posted December 05, 2006 - 06:00 PM
If you've got a digital camera or a poleroid-take a couple of close-up pictures before you dismantle the original. you'll be glad you did later...
  • guybmoto
Posted December 06, 2006 - 12:38 AM
Here's the complete article that goes along with that video...
http://www.vitalmx.c...d=601&Itemid=32
  • Hot  30 replies
  • Hot  47 replies
  • On January 15, 2017
  • Hot  38 replies
