Starting
10 replies to this topic
  • kx256
Posted December 05, 2006 - 11:26 AM
Anyone have a hard time getting a 07 started. This is my first new bike that has been this hard to start. I've only got about an hour on it so that might be it but I was just wondering if anyone else had this problem.
  • kxman
Posted December 05, 2006 - 12:02 PM
I had a hard time starting my 06 when I first got it. I was used to a 2 stroke. Depending on the temp., first time starting for the day, I give it from 2 to 4 twist of the throttle, pull out choke. Then do not touch the throttle while kicking. I grab onto the handlebars but not the grip. Kick it fully through, nice long smooth kicks, and it will start right up.
When my bike was new I tried to start it as soon as I got it home and wore myself out. After learning the procedure it starts very easy. As a matter of fact I can and have started it with my hand.
  • ausgeflippt13
Posted December 05, 2006 - 12:18 PM
if you're still having trouble, try kicking it like how the old BSA's and Nortons and other brit bikes like to be started: by kicking it hard with the comp release open, but about a third of the way thru the kick let it go fast (let it go similarly to popping a clutch). this will get you past TDC and allow you enough momentum in the motor to get more than a stroke or two (which is most likely your problem). The ignition will kick in and you'll be running.
Posted December 05, 2006 - 01:35 PM
Of all the hundreds of old British bikes I've started, I never did anything like that.
Besides, are you going to help him find the compression release on his '07?
  • WB450
Posted December 06, 2006 - 09:36 AM
My 07 was the same way, 3 to 4 twists on the throttle and smooth kicks did the trick.
  • kyle450rider
Posted December 06, 2006 - 04:30 PM
What was your favorite of the hundred's of british bikes you owned?
Posted December 06, 2006 - 05:17 PM
Didn't own hundreds, but I worked on them for a living, and of those I did own, there are several I wished I had never sold. There were so many great ones. One of my own favorites was the '71 BSA B50MX. Another one was the G85 Matchless with the factory Rickman frame. A couple of Goldstars, and a pair of Norton twins. I also had an early Triumph Trident for a while.
Only the singles had compression releases.
  • kyle450rider
Posted December 07, 2006 - 06:13 AM
I really like the old triumphs.
  • kx256
Posted December 07, 2006 - 09:59 AM
I went to practice last night and after my first moto it started pretty easy. It just made me a little nervous that a new bike wasn't firing right away. I had an RMZ 450. It feels good to get on something with 5 gears.
  • DrThumper
Posted December 07, 2006 - 11:37 AM
The Old Just-learning-how-to-start-a-thumper-routine again. Don't worry Grasshopper, soon it'll be as routine as blowing your nose.
  • ONLY4STROKES
Posted December 07, 2006 - 01:51 PM
A few quick blips of the throttle helps to prime the accelerator pump for starting.
Being smooth and quick is emphasized. No need to ironman the thing.
  • Hot  28 replies
  • 0 replies
  • Hot  38 replies
