A question for the little guys
10 replies to this topic
  • rubys-dad
Posted December 01, 2006 - 07:06 PM
Yep another long time lurker, blah, blah, blah.
I'm 5'6 140, '05 wr450, she's a bit tall for me, so I thought I would deflate the tires so I could touch the ground, any thoughts?
Just kidding about the tires, I did see an ad in dirt rider about a modified rocker link, it would lower the bike 1.5 inches, any shorties like myself try it?
  • sandman76513
Posted December 02, 2006 - 05:28 AM
Modifying the suspension via a new link is one choice, then slide the fork tubes up in the fork clamps a bit. Another thing to consider is changing out the springs front and back, from the factory the 06 WR is set up for a 180 pound rider...at 140 lbs you are not compressing the suspension much when you straddle the bike. You also should adjust the sag for your weight.
  • CAVSCOUT96
Posted December 02, 2006 - 06:09 PM
http://www.fullcircl...om/lowering.htm
I did this and I've been VERY pleased with the results
  • jasilva
Posted December 02, 2006 - 09:25 PM
You can also trim the seat down. It not only lowers it but you get a softer seat this way. I think the surface foam is harder because of the finish on it by cutting this away it allows the seat to flex more. Here's a pic of mine after cutting the seat.
If you decide to do this the best method is using an electric carving knife and then smooth it and contour it with a random orbit sander.
Joe
  • MN_Paul
Posted December 02, 2006 - 09:53 PM
I looked around at the full circle site and cant find what they do and what it costs to lower a bike.
Paul
  • ahoolsema
Posted December 02, 2006 - 11:01 PM
Easiest way to lower the bike is to put on some weight. Strict diet of donuts, sugary drinks, beer, and all things deep-fried. The bike will be sagged down in no time!! :D
PS welcome to the discussion, lurker.:worthy:
  • Just_a_trail_rider
Posted December 03, 2006 - 02:04 AM
Paul
excellent question. What is it that they do?
  • farkawi
Posted December 03, 2006 - 12:15 PM
Ok, you're not too far from Davey Durelle, who is a good suspension tuner. http://www.durelleracing.com/
  • rubys-dad
Posted December 04, 2006 - 07:24 PM
Sorry not to respond earlier but had to go to Spokane,Wa. for my dads 80th b-day. Still trying to figure out full circle as well.
Farwaki thanks for the link, thats what I think I'm looking for is for a pro to set it up for my build, but this whole winter crap thing is getting in the way!
  • CAVSCOUT96
Posted December 05, 2006 - 12:35 PM
IN my case I had Full Cirle redo both ends of my suspension completely
stiffer shock spring
rebuild shock valving and seals
stock fork springs
rebuild fork valving and seals
fresh juice
Call Dave Lampmann fo rin depth of how active reach works. IN laymans terms it reduces the overall hieght (i want to say using a captured spring type setup) and reduce the seat height without limiting overlll travel.
Suspension is really kinda like vodoo to me that's why I went to a pro tuner to lower for me.
Total cost including a COMPLETE suspension rebuild and service came it at about 450. I think the active reach by itself comes in around 200, but he did my almost two years ago so prices may have changed a little.
I've been very pleased with the setup.
  • ausgeflippt13
Posted December 05, 2006 - 12:43 PM
Norman Kouba (koubalink.com) makes lowering links for pretty much everything except for yamaha yz's and wr's. That said, if you've got something else that needs to be lowered, kouba links are the way to go. They're really quality stuff and they work fantastically (assuming you lower the front forks in the triple clamps as well. I've even heard thru the grapevine they actually increase suspension travel, but just briefly thinking about it that contention sounds unlikely. I haven't really bothered to apply the trig necessary...
However, for yz's and wr's, Norm Kouba recommends this site: http://www.mountainm...lower-link.aspx
They've got the lower link for our bikes, assuming they're a 2001 or newer. Not sure how much they lower the bike, tho...
Yeah I know, perhaps this post was a little useless...oh well.
