Bar diameter and GPS Mounts
11 replies to this topic
  • evomx971
Posted December 01, 2006 - 11:19 AM
I want to put a set of RSW top triple clamps on my XR650L and a set of nice bars. I like Pro Tapers and would like to put those on but would also like to install a GPS and mount at some point. It looks like most GPS mounts are set up for 7/8 bars. Are any of you running a GPS mount on Pro-Tapers? Is there enough 7/8 bar on the ends of a Pro Taper bar to get a GPS mount on there, especially on the L where the bars are kind of busy with switches and perches?
Thanks!
Kelly
  • tommyj92028
Posted December 02, 2006 - 11:32 AM
I have a garmin 176c that uses a RAM mount. RAM makes the mounts that have the rubber coated balls. I got the "U" shaped clamp that fits bars from 3/4" to 1 1/4" and use it on the "fat" part of the bar by the bar clamp. I'll try to post some pictures. RAM makes all kinds of stuff, so you can go on there website and find your gps model and see what they make for it. Hope that helps, Tommy
  • dukeryder
Posted December 02, 2006 - 10:31 PM
^ Yup I have the Ram Mount for my Garmin V and the same ball worked on the 7/8 bars and the 11/8 Pro-Tapers.
  • Boston Mangler
Posted December 02, 2006 - 11:16 PM
I use the garmin mount for my eTrex and it works flawlessly!
It was like $11 at REI
  • evomx971
Posted December 04, 2006 - 08:40 AM
Perfect, looks like I can go with whichever size bars I want, thanks for the info and pictures!
Kelly
  • Evilfirbolg
Posted December 13, 2006 - 03:07 PM
Hows yer e-trex holding up? Seems the vibration is killing mine in a similar mounting place.
  • Boston Mangler
Posted December 13, 2006 - 07:50 PM
The eTrex is still working great and taking a hell of a beating!
:thumbsup:
I had some issues with it shutting off randomly and it turned out to be that the batteries we coming loose. I just stuffed some tissue in between the batteries and the battery cover and not a single problem since!
Whats yours doing??
:devil:
  • HighRevz
Posted December 14, 2006 - 01:24 AM
Garmin website.:thumbsup:
  • olinmat
Posted December 14, 2006 - 05:39 AM
Great GPS info/products at
www.cycoactive.com
  • Evilfirbolg
Posted December 15, 2006 - 09:41 AM
:thumbsup:
Whats yours doing??
:devil:
The exact same thing, and I did the exact same thing, then sometimes the screen gets screwy. I wack it one and it gets ok then it screws up again. Weird little beasty.
  • rmhrc630
Posted December 15, 2006 - 04:07 PM
Thanks!
Kelly
try this
  • evomx971
Posted December 15, 2006 - 05:51 PM
nice setup, thanks for posting!
  • 3 replies
  • 4 replies
  • Hot  29 replies
  • 17 replies
