Iridium Plug Info for 650R Guys
15 replies to this topic
  • philipstjohn
Posted December 01, 2006 - 06:36 AM
Anyone using an Iridium plugs with a comment? I am looking for a NGK Iridium plug number for the XR650R. Anyone know it? Thanks in advance for your help...:worthy:
  • BWB63
Posted December 01, 2006 - 06:57 AM
Spark plugs
NGK IX Iridium 6988 BKR7EIX-11 $6.95
I run this and it is worthy of the extra money.
NGK Double Platinum 4853 PFR7B $11.71
I have tried these and they are good. No misfiring problem stock BKR7E $2.24
Split fire for XR650R
TP392B or SF392D
I ordered them for www.sparkplugs.com and they got here in 3 days!
  • frankstr
Posted December 01, 2006 - 07:15 AM
I use a Iridium plug...In all my rides that burns gas...:worthy:
:D :prof:
  • Agent2
Posted December 01, 2006 - 09:35 AM
Just to be the devils advocate, are you going to get improved performance spending the extra cash on the Iridium plug? Most xr owners know that a properly tuned bike will start first or second kick and a regular plug will last quite literally for years. I change the plug once a year as part of my maintenance routine, the one I'm replacing always looks in great shape.
  • cleonard
Posted December 01, 2006 - 10:26 AM
I'm with Agent2 on this one. Has anyone ever done objective testing, like a dyno test, with these special plugs and seen any difference?
  • rcnutt
Posted December 01, 2006 - 03:13 PM
great , now lets talk oil.........
  • eastreich
Posted December 01, 2006 - 03:18 PM
Then we'll start on the av-gas...
  • my98mugen
Posted December 01, 2006 - 03:49 PM
I would rather spend 5 bucks more on the plug then rent a dyno.
  • sokalbike
Posted December 01, 2006 - 04:13 PM
:worthy:
  • InternalCombustion
Posted December 01, 2006 - 04:15 PM
I got 7k invested in my xr650r. Spending an extra few bucks for an iridium plug seems a no-brainer.
I use a Denso #5310 Iridium plug, $13. My logic is if it only once saves me from a fouled condition or provides a bit extra spark at the donut shop, with all the Harley guys watching me kick, then it was worth it.
I am like the frankster, I run iridium in all my bikes.
  • Huffa 2
Posted December 01, 2006 - 05:39 PM
I still have the original Iridium plug in my 02 CRF 450. In the long run they turn out to be cheaper then a stock plug or even a platinum jobber.
Do you guys know where iridum comes from? I didn't but just found out and I think if I told you, you would say I was wacko or something.
  • Huffa 2
Posted December 01, 2006 - 05:50 PM
:D It came from outer space :prof: :worthy:
http://csep10.phys.u...rs/fireball.mpg
  • R1-xr650-400
Posted December 01, 2006 - 06:09 PM
the only difference you'd see on a dyno test from changing a spark plug on an XR-650, would be due to the dyno variances, air density changes, etc.
you might see a difference on some ultra high compression, high horsepower vehicle, but not an XR. ;(
spent a LOOOOOT of time around dynos, and tried this myself on my Supra, and the only power differences I saw, were equal to the power differences I saw between two sets (of 3) runs I did, where nothing was changed.
I also raced a friend of mine (whom I race all the time) after I changed to an iridium plug in my 650, and the results were the same as they always were. and we did about 5 or 6 races to 100mph.
Posted December 01, 2006 - 06:26 PM
I don't think anyone is saying there'll be a performance improvement, power-wise. What you will see, as huffa2 said, is a plug that has a much improved resistance to fouling.
The electrode on my Denso (and I assume on the other iridium plugs) is super-fine. What that does is focus the spark into a very small surface area, thereby making it a bit higher temperture, and the electrode stays carbon-free longer, particularly under rich-mixture conditions.
Harley's are renouned for fouling if you leave the enrichner (choke) out too long during warm-up. An iridium is less suseptible to fouling (yeah, my Harley's have iridium plugs, now).
I did not notice any increased power when I changed over to iridium. I did it for reliability reasons.
One last point: all plug threads should get a bit of anti-seize lube on them when you install them. Platinum or Iridium plugs particularly should be thus prepped, as they tend to be left installed in the head longer.
  • cleonard
Posted December 02, 2006 - 08:35 AM
That's sort of what I thought. As a point of reference, I have had 4 XR's and XL's over the years and I'm sure I have put a large amount of miles on those bikes. Maybe as much as 60,000. In all that time I have used at most 7 or 8 plugs. I never had anything that resembling a fouled plug. Even when running sea level jetting at 10,000 feet. It was so rich that the plug got black with soot, but kept working fine.
Ok, now that I said that I'll probably foul a plug today.
  • motopsycho650
Posted December 02, 2006 - 09:31 AM
I agree here. I've been using the stock NKG plugs. Nothing special. I have my bike tuned very well, and the plug is always a golden brown. If the bike is tuned correctly, any plug will easily be able to ignite the fuel/air mixture.
Actually, I believe that if you do feel a power gain from a more expencive plug, that is an indication that the fuel/air mixture was not optimised to begin with.
  • 9 replies
  • 3 replies
  • 22 replies
  • 17 replies
Honda XR650L 2016
  • 0 reviews
