Countershaft Sprocket Bolt Torque Specs?? Lock-Tite or No?
9 replies to this topic
  • Boston Mangler
Posted November 29, 2006 - 06:09 PM
Hey Guys
Got my new 14T front sprocket and "Hand Tight Installed" it.
I cant find a torque value for those 2 little bolts anywhere. Any ideas?
Also, do you guys use lock tight on them?
Another weird thing, now the chain seems way too big, when i adjust it to the "freeplay" specs, it is in the red zone on the adjusters! :worthy:
Its only got like 1300 miles on it?
Thanks
:D
  • ej67ss
Posted November 29, 2006 - 06:29 PM
just get them tight and maybe blue lock tight. I change mine all the time and they have never backed out on me but i do check them often.
  • tirebiter
Posted November 29, 2006 - 06:45 PM
I tighten them down to about 15lbs, and use blue lock-tite.
  • Boston Mangler
Posted November 29, 2006 - 07:01 PM
Thanks Guys
  • BRPXL600R
Posted November 29, 2006 - 07:02 PM
Loctite 242 blue!
  • goblin127
Posted November 29, 2006 - 08:38 PM
Now your just gonna have to go out and get that 48 t rear sprocket.
  • frankstr
Posted November 29, 2006 - 08:40 PM
I'd say no more then 8 to 10 ftlbs...blue loctite.....
:worthy: :D
  • cleonard
Posted November 29, 2006 - 10:43 PM
:worthy: :D
Unlike the 6mm fasteners that go in the aluminum engine block, the ones for the sprocket are going into steel. Ten ft-lbs is a good absolute max for 6mm bolts in aluminum. Fifteen is OK for the sprocket bolts. Because of the higher torque, I've never used loctite on those bolts. The rear sprocket is a different matter. They always seem to come loose without the loctite.
Are you running a non-ring type chain? They can wear (stretch) real fast.
  • Boston Mangler
Posted November 30, 2006 - 05:41 AM
Crap, i think i overtightend them. I will most likey replace them! Damnit!
Stock chain, which i THINK is a 520 O-Ring
  • Boston Mangler
Posted November 30, 2006 - 05:36 PM
FYI, i just bought 2 new bolts/screws to be safe and they came with some sort of locktite stuff preinstalled
Thanks
Honda XR650L 2017
  • 0 reviews
  • Hot  60 replies
  • 9 replies
  • Hot  35 replies
