Anyone have photos of their 06 w/Clarke or IMS tanks?
29 replies to this topic
  • Kyle Prior
Posted December 01, 2006 - 10:41 PM
#21
The IMS for my 00 426 did come with a new petcock....
Posted November 05, 2007 - 08:21 PM
#22
Here's a modification I did to clean up the dual petcock installation on the '06's. At first, I had it connected with a angled T fitting, like this:
To eliminate the T, I bought a 5/16" inverted flare to hose fitting like this one. The extension that the hose slides onto needs to look like this, and not like those you find that have multiple barbs on them. Try to get one as near to .312" diameter at the shank of the extension as you can.
Cut the extension off flush with the hex, file it square if needed, and chamfer the cut end until it's smooth and uniform. Now, you will need to push this into the round precast blank outlet pocket in the petcock body opposite the existing outlet tube. It is important to use a piece of tubing, a socket, or a combination of washers, or whatever over the existing tube so that the pressure is put on the body, and not on the existing tube. Otherwise, the existing tube will be driven into the petcock body. I used a vise as a press for this operation.
Push the new tube in until you feel it bottom in the precast pocket. You must push it in squarely, or it may not seal. Once in place, use the largest drill that will fit freely down the new tube, and carefully drill through the blanked off outlet port into the center of the petcock body. Remove all chips thoroughly. When you're done, it should look like this:
  • cowboyona426
Posted November 10, 2007 - 06:18 PM
#23
Leave it to grayracer! Looks slick. The hot setup would be to eliminate the petcock on the right side, and just have an elbow fitting over there to hook the hose too. Run with it grayracer! :thumbsup:
Posted November 10, 2007 - 07:23 PM
#24
In order to do that, the left side cock with the two outlets would need to be made differently so that it shut both the ports off individually, instead of closing the port that leads into them.
Besides, having a valve on both sides allows you to remove the fuel tank for service with having to drain it or find a way to clamp off the hose from an elbow.
  • WB450
Posted November 11, 2007 - 09:18 AM
#25
  • rtgincnm
Posted November 11, 2007 - 05:23 PM
#26
WB450
Is that the stock petcock? Love the way it looks, should get mine next week.
  • WB450
Posted November 12, 2007 - 08:31 AM
#27
WB450
No sir, it's a petcock for a 05. There are a few that point the right way, for $20, it was worth it to me.
Maybe it's a 04, go to the dealer and ask to look at one.
Posted November 12, 2007 - 08:51 AM
#28
'03-'05, all the same. Did the same thing on mine. $17 each from TT OEM.
  • pbviking
Posted December 09, 2009 - 06:30 PM
#29
anyone know if the petcock above is for a wr or yz?
Posted December 09, 2009 - 07:28 PM
#30
That was for a YZ. A WR will fit, though.
  • 10 replies
  • Hot  50 replies
  • Hot  113 replies
  • 0 replies
