Common OEM Part Numbers
6 replies to this topic
  • clark4131
Posted November 27, 2006 - 04:20 PM
Things to remember...
Yamaha Parts Fiche Website
Yamaha Jet Part Numbers
MAIN JET
4MX-14943-88-00 .JET, MAIN (#152) AP 1
4MX-14943-38-00 .JET, MAIN (#155) AP 1
4MX-14943-89-00 .JET, MAIN (#158) AP 1
4MX-14943-39-00 .JET, MAIN (#160) AP 1
4MX-14943-90-00 .JET, MAIN (#162) AP 1
4MX-14943-40-00 .JET, MAIN (#165) STD 1
4MX-14943-91-00 .JET, MAIN (#168) AP 1
4MX-14943-41-00 .JET, MAIN (#170) AP 1
4MX-14943-92-00 .JET, MAIN (#172) AP 1
4MX-14943-42-00 .JET, MAIN (#175) AP 1
4MX-14943-93-00 .JET, MAIN (#178) AP 1
PILOT JET
4MX-14948-01-00 .JET, SLOW (#35) AP 1
4MX-14948-02-00 .JET, SLOW (#38) AP 1
4MX-14948-03-00 .JET, SLOW (#40) AP 1
4MX-14948-04-00 .JET, SLOW (#42) AP 1
4MX-14948-05-00 .JET, SLOW (#45) STD 1
4MX-14948-06-00 .JET, SLOW (#48) AP 1
4MX-14948-07-00 .JET, SLOW (#50) AP 1
STARTER JET
3TJ-1494F-12-00 .JET (#62) AP 1
3TJ-1494F-13-00 .JET (#65) STD 1
3TJ-1494F-14-00 .JET (#68) AP 1
3TJ-1494F-15-00 .JET (#70) AP 1
3TJ-1494F-16-00 .JET (#72) AP 1
3TJ-1494F-17-00 .JET (#75) AP 1
3TJ-1494F-18-00 .JET (#78) AP 1
3TJ-1494F-19-00 .JET (#80) AP 1
3TJ-1494F-20-00 .JET (#82) AP 1
LEAK JET
4JT-1494F-01-00 .JET (#35) AP 1
4JT-1494F-03-00 .JET (#40) AP 1
4JT-1494F-07-00 .JET (#50) STD 1
4JT-1494F-11-00 .JET (#60) AP 1
4JT-1494F-15-00 .JET (#70) AP 1
4JT-1494F-19-00 .JET (#80) AP 1
4JT-1494F-23-00 .JET (#90) AP 1
4JT-1494F-27-00 .JET (#100) AP 1
Fuel Screw Parts
O-RING: 3TJ-14562-40-00
WASHER: 3TJ-14952-40-00 WASHER
COIL, SPRING: 3TJ-14160-40-00 COIL, SPRING
'03+ YZ Exhaust Cam: 5TA-12180-00-00
'03+ WR Exhaust Cam: 5TJ-12180-10-00
YZ Throttle Stop Screw (39MM Keihin): 5JG-14591-00-00
Water Pump Part Numbers
IMPELLER SHAFT : 5GR-12458-00-00
OIL SEAL : 93109-11073-00
OIL SEAL,SD-TYPE : 93102-12321-00
BEARING : 93306-00105-00
GYT-R AIS Kits
'05-'06 : GYT-5TJ93-69-00
'07+ : GYT-5TJ93-69-01
Where to buy this stuff:
TT Store
Sudco (Jets)
Bike Bandit
Zanotti's
Bookmark this stuff...SC
  • byggd
Posted November 27, 2006 - 04:54 PM
SC are you going to make this a sticky?
  • clark4131
Posted November 27, 2006 - 05:02 PM
Nope, it's included in the Performance Index already :worthy:...SC
  • bluebike1999
Posted November 30, 2006 - 01:32 AM
i find using this is handy to ascertain common parts.
http://www.ronayers....h/whereused.cfm
some seals are used on up to 93 different yamahas
  • Wasabi
Posted November 30, 2006 - 04:33 AM
Where's the 2 PAJ's?
  • kcolyar
Posted December 05, 2006 - 07:00 PM
I have an 03 450. What is my stock main jet. I bumped mine up to a 168. I ride at 4000ft here in Moab. from 50 to 100 degrees. I removed the baffle on my stock exhaust and opened up the airbox along with the free mods. Any suggestions for the jetting, I have a slight hesitation right off idle and it seems a little choked on the very top. Mid range seems strong. Any help will be appreciated. This is my first 4 stroke after years of 2 strokes.
  • Gadsen
Posted December 06, 2006 - 03:05 PM
MAIN JET
Good info. Interesting, my Canadian 04 WR450 came stock with a 160 main jet.
