First time jetting
13 replies to this topic
  • CheYuen
Posted November 27, 2006 - 03:18 PM
I ordered the AIS removal kit, JD jetting kit, and fuel screw from the TT store which should be arriving in a few days. I know little to nothing about jetting and carbeuration. Are there any special tricks I should know? Is there anything else I should be doing while I have the gas tank off and carb out?
I asked this question in the carbeuration forum but did not get an answer. I see that the JD jet kit comes with main jets and needles but what about the leak jet and pilot jet? Do I buy these separately? Thanks everyone.
  • CheYuen
Posted November 27, 2006 - 04:39 PM
I ride a 2005 WR 450
  • byggd
Posted November 27, 2006 - 04:52 PM
Check this thread out. I think you will find most of your answers :worthy:
http://www.thumperta...ad.php?t=411240
  • clark4131
Posted November 27, 2006 - 05:01 PM
After that, check the Performance Index. It gets better everyday...SC
  • kskyles
Posted November 27, 2006 - 08:35 PM
make sure to check out these tutorials for jetting and AIS removal
http://www.thumperta...ad.php?t=309069
http://www.thumperta...ht=AIS tutorial
good luck. i've had good success using indy's jetting guide as a place to start.
  • CheYuen
Posted November 28, 2006 - 12:08 PM
Thanks everybody, I feel more comfortable doing the work myself now. I am still wondering though; do I need to buy leak jets, starter jets, and pilot jets separately from the JD jet kit?
  • drtbk4ever
Posted November 28, 2006 - 12:09 PM
I agree with using Indy's jetting guide as a place to start. But the best resource is the link above to Arin's DIY jetting guide WITH pictures. This is a priceless piece of work. Helped me tremendously.
Cheers.
  • J_DOGG
Posted November 28, 2006 - 12:20 PM
I have an 04 WR450 and run all stock except the needle and main... the bike runs good, I'm sure it could be better but it runs good with just the basic JD kit.
You can go crazy with jetting or just jet to get the job done, the choice is yours.
  • kskyles
Posted November 28, 2006 - 01:07 PM
the JD kit only comes with an assortment of main jets, so you'll have to buy the rest seperately.
i called sudco, and they were helpful and fairly cheap. if you talk to the sales guys and tell them you have a 39mm Keihin FCR carb, they can hook you up with some jets. it was much cheaper and easier than dealing with the part monkeys at your local dealership.
  • Seabass
Posted November 28, 2006 - 02:59 PM
Also look at www.thumperfaq.com. There's good info on jetting there as well.
  • Oasis_Flame
Posted November 29, 2006 - 09:48 AM
So why are you guys removing the AIS, is there a big gain? I ride an 01 WR426 and mine is still on the carb and the bike runs like new.
  • Fullbore4
Posted November 29, 2006 - 11:03 AM
Could be the reason you didn't get an answer in the carb forum is because there are so many things you can do to alter the carburator, AIS, cam, etc. (all inter-related) that alter performance that nobody has a single answer. One has to take a few things apart and then refer to this whole site to dig up info on that item (most likely its here). One has to gain at least a basic understanding of what your trying to modify and be more concise in what you ask.
  • clark4131
Posted November 29, 2006 - 11:28 AM
I'll give you $100 if you can send me a pic of the AIS on your bike...:worthy:
The AIS didn't show up until '05, so you ain't got one...SC
  • CheYuen
Posted November 29, 2006 - 12:32 PM
My question was if I had to buy the pilot jet, starter jet, and leak jet seperately from the JD jet kit - concisely. Otherwise I am just looking for general advice since this will be my first time venturing into a carbeurator.
Thanks everybody for your input. I think this will be fairly easy to do with all of the clear explanations and pictures here on TT. :worthy:
