2002 Yzf426 fouling plugs like nuts
16 replies to this topic
  • michmex
Posted November 27, 2006 - 09:55 AM
I was wondering if this was commin cuz it seem to do it alot and it is starting to get $. kills plugs to point i cant clean them off
I NEED HELP
  • GONE1445
Posted November 27, 2006 - 10:07 AM
do you start your bike and not let it get up to full operating temp a lot
if you start it you gotta let it run a little and get hot enough otherwise you will foule a plug pretty quick
are you cleaning your plugs when they foul and putting them back in??
if so how do you clean them, DO NOT by any means sand blast them and reuse it that is a bad idea
  • michmex
Posted November 27, 2006 - 10:19 AM
no i take a wire brush to it i think when it blows it fries the electrode all the way though but my buddys bike does the same thing just keeps fouling plugs
  • trail
Posted November 27, 2006 - 10:32 AM
Mine was doing this also, do the BK mod! stopped mine... Correct jetting and the bk mod My bike runs killer and has 8 hours on the plug.
search for bk mod
  • michmex
Posted November 27, 2006 - 10:34 AM
8 hrs ? only that F^^^ it that the normal plug time ?
  • trail
Posted November 27, 2006 - 10:38 AM
before the bk mod my bike would foul a plug in 2-4 hours of ride time. My current plug has 8 hours on it and still runs great, I have no plans on changing the plug and im sure Ill get more hours out of it.
  • michmex
Posted November 27, 2006 - 10:40 AM
ahh ic well thanks for the info hopefully i get my problem fixed
  • michmex
Posted November 27, 2006 - 10:41 AM
ill tell you wut i come out with
  • michmex
Posted November 27, 2006 - 11:02 AM
would adding a pipe and not jetting it be the problem to ?
  • Dustykat
Posted November 27, 2006 - 04:11 PM
I did the BK mod, set the timing correctly and I've been on the same plug for the whole of the 2006 racing season.
They will last if you warm up the bike and do the carb mod. Before I did it I'd flood the bike just thinking of touching the throttle.
:worthy:
  • michmex
Posted November 28, 2006 - 10:27 AM
lol that could be my problem never letting the bike warm up never realy did thank for the info
  • byggd
Posted November 28, 2006 - 11:30 AM
As stated do the BK mod. Stock the acc pump has over a 3 second spray time and with the mod you can get it down to under a second. If you need instructions go here.
http://motoman393.thumpertalk.com/
  • sirthumpalot
Posted November 28, 2006 - 04:50 PM
My 01' used to foul plugs, but it was because i would start it, run it for like 1 minute then turn it off. When I started making sure it got up to full temp before shutting it off for the day then the plugs started lasting months and months.
  • 642MX
Posted November 28, 2006 - 05:52 PM
Don't overlook the valve clearance. I had a tight center intake valve that caused me to foul a couple plugs on start up. I reshimmed the valve and all the problems went away.
  • felix 222
Posted November 28, 2006 - 06:35 PM
running rich?
  • Triple8
Posted November 30, 2006 - 02:52 PM
Do you have it jetted correctly, I have about 15 hrs. on mine with no problems. starts easily.
  • michmex
Posted March 20, 2007 - 09:06 AM
well i got too many on mine i use for trail and that other fun stuff
