07 450f suspension advice needed...please help
5 replies to this topic
  • mx43yzf
Posted November 26, 2006 - 06:26 PM
I tried the suspension forum first but got no responses.
I dont know a whole lot about suspension but am learning.
I had the springs changed before I even rode it because I weigh 150 pounds without gear.(5.2 rear .42 front) When I got it back from my suspension guy I didnt check the sag because he said it was set and I would have to check it and reset it after a couple of hours anyway. Anxious to ride it I did. I also dropped the triple clamps down on the forks 4 mm (I have had success with this on other bikes and read here on thumpertalk that this helps in turn in). I thought the suspension was great. I have been riding on a new indoor track that has hard, hard, hard pack soil. Did i mention the soil is hard? I think its clay. Anyway I checked the sag and it was at 85 mm. So I changed it to 95mm and although the bike still turns well (maybe not as good as before) It appears I dont get the same lift in the rear(which I'd like back) when I am doubling up the rockers/whoops at this track.
I checked my static sag and its at 35mm when the race sag is 95 and 30 when the race sag is 85. I read that the static sag should be between 15 and 25 mm or the spring is wrong for my weight.
I got the spring rates at race tech website. Is my shock spring still to stiff? Is the front to stiff too??
Thanks in advance.
Tom
  • YZ250F_Rider
Posted November 26, 2006 - 06:30 PM
ummm if it worked great at 85, put it back.
Posted November 26, 2006 - 07:18 PM
According to rule of thumb conventional wisdom, your springs are too stiff. The bike is sprung for riders in the 165-180 pound range. The deep free sag that you have at 95mm race sag indicates the spring has too high a spring rate for you, and since the front and rear are well matched from the factory, I'd say both ends were wrong for you.
Of course, this is a basic rule for most people, and not everyone. If you are a very fast rider, you may find that stiffer springs work for you. But for most, the standard guidelines hold up.
  • mx43yzf
Posted November 26, 2006 - 07:24 PM
grayracer, I did change the springs see to 5.2 rear .42 front. So are my springs still to stiff???
  • max49
Posted November 26, 2006 - 08:17 PM
This is not much help to you, but did you put a titanium spring in the rear?
I guess we or he doesnt know much about suspension because he likes it just the way the 07 came. He weighs 140lbs. I adjusted the preload about as soft as I dare and he has about 31/2" of sag.
Posted November 26, 2006 - 08:40 PM
MX Tech's spring generator suggests .43 fronts and 5.1 rear for a rider who weighs 160 in gear, and .44/5.1 for one who weighs 165. You are pretty close, and while you may still want a softer rear spring, you can probably work with what you have.
And just as a sort of disclaimer, I don't consider suspension tuning to be one of my strongest skill areas.
  • 5 replies
  • Hot  79 replies
  • 9 replies
  • Hot  47 replies
  • 0 reviews
