YZ 426, using replacement threads in the oil filter cover bolt area.
6 replies to this topic
  • Dustykat
Posted November 26, 2006 - 12:52 PM
So, it finaly happened. The oil drain bolt in my YZ 426 pulled it's threads out of the case. I knew it was coming as the guy I bought the bike off of told me they were "kinda loose" what ever that ment.
But anyway, what is the prevaling opinion on using a replacement thread kit in this area. I know the little prong off the thread coil will be importaint to find but will the threads hold well enough to do this or am I stuck with buying a case half?:D :worthy: :prof:
Thanks
  • Goosedog
Posted November 26, 2006 - 01:37 PM
Same thing happened to my '02...reported cause was user neglecting to flush out the threaded holes with WD (or the like) during oil changes.
I was able to 'heli-coil' all three holes back to the original size without removing cases and got all new bolts (OEM) and it's good as new. :worthy:
  • Nova1194
Posted November 26, 2006 - 01:47 PM
Helicoils will last longer and be stronger than the original thread was, as far as finding the little tang goes, I modifed a pair of small needle nose pliers to grab it with, work it back and forth and plull it out, I also installed magnetic drain plugs when I was done.
Mike
  • never59
Posted November 26, 2006 - 02:52 PM
Same thing happened on my 02 426. Helicoil is the way to go!
  • Dustykat
Posted November 26, 2006 - 04:06 PM
Ok guys, sounds good. But what size should I look for? Also where did you buy your Helicoil sets?
Thanks!
:worthy:
  • CRFThumper
Posted November 26, 2006 - 04:13 PM
If we are talking about the oil filter housing they are 6 mm.We just go to the local auto parts house and get them!Napa or the like will have them.
  • Ga426owner
Posted November 26, 2006 - 04:23 PM
Here is what I used on my older 426's. I think a better design
http://www.timesert.com/
  • Hot  36 replies
  • 5 replies
  • Hot  47 replies
