"L" with a E2,Uni & rejetted....hold on.
11 replies to this topic
  • DockingPilot
Posted November 26, 2006 - 10:02 AM
I have the DynaJet kit installed with a 55, Uni filter and WB E2 pipe, also a 14t. She leaps ! Idles, starts and rips.
I recommend it.
  • frankiewhipit
Posted November 26, 2006 - 03:58 PM
Yea Me To, Mine Was Jetted, Desnorkled & Dave Modded, Then I Installed The E2 Last Week, I Still Cant Believe It's The Same Engine
  • DockingPilot
Posted November 26, 2006 - 04:16 PM
And here she is:
And for real precision work:
  • elrontx
Posted November 27, 2006 - 10:18 AM
very nice! where did you get the headlight?
  • DockingPilot
Posted November 27, 2006 - 10:35 AM
Baja Designs. Plugs right in.
  • Boston Mangler
Posted November 27, 2006 - 06:05 PM
I recommend it.
What do you mean a 55? Did you change your pilot to a 55? Which main ya running?
My E2 should arrive weds! :worthy:
P.S. JESUS that bike it LONG :D
  • DockingPilot
Posted November 28, 2006 - 04:21 AM
Simply install the entire Dynajet kit, spring and all. Use the 165 main not the 160 in the kit because you have the pipe like me. E-clip in the 3rd slot. Then grind off the tab on the fuel mixture screw and seat it then screw it back out 2.25 turns. Then put in a 55 pilot. I ordered mine from XR's Only. The kit does not come with a pilot. But most feel that it is still needed. I agree after installing mine. So you have the entire DJ kit installed plus a 55 pilot jet.
I know nada about carbs, so when I was re installing it, I was thinking to myself "if this flipping thing starts and runs right it will be a miracle". Well, I hit the happy button and she lit right off ! Idled great, ran great. Gone is the low end hesittation and she is very smooth and responsive.
My friend Wil who knows a lot about this stuff held my hand through the operation and gave me the jet combo to use. He was correct. :worthy:
  • DockingPilot
Posted November 28, 2006 - 04:24 AM
To be clear, this is for the 650 not the 250 and certainly not the bad assed 950 !
  • Boston Mangler
Posted November 28, 2006 - 05:29 AM
Ok Thanks
As my bike sits now, it has the DJ Kit (with the 165 main), Uni Filter, Desmogged, DeSnorkeled, and the Baffle removed, runs well but i am waiting to install my pipe!
I will run it as is for a bit and then install the 55 if needed. I run at high elevations a lot so i migth not need it, i will see!
Thanks
  • DockingPilot
Posted November 28, 2006 - 05:34 AM
Good luck, hey dont mangle anyone, I think the coppers are on to ya :worthy:
  • wwjam
Posted November 28, 2006 - 05:40 AM
Hey Frank,
Bike looks great! Glad the carb mods worked out.
Later
Wil
  • DockingPilot
Posted November 28, 2006 - 05:52 AM
Thanks for all the help Wil. I would still be messing with it if not for you.
See you Sunday. Bring a flashlight with you. I posted an update on ADV. Make sure Jorge and Bill see it.
