Cam Chain Replacement?!
3 replies to this topic
  • boer
Posted November 26, 2006 - 02:32 AM
I am trying to get more info on the intervals for changing the cam chain. I have heard on some other threads that once a year is mentioned. No recomended interval is mentioned in the maintenace manual though.
What intervals are you guys going by? Any input from the high milegae guys, Indy, simon@vic etc:thumbsup:
  • Indy_WR450
Posted November 27, 2006 - 05:30 AM
I did mine at 12,000 miles. The sprocket on the crank is pretty hooked so you end up replacing the crank at the same time.:worthy:
  • boer
Posted November 27, 2006 - 06:07 AM
Thanks Indy, that's what I was hoping for. 20000km for so sounds good. I will not worry any further then.
So when you rebuild the engine with a big bore and crank kit would be the ideal time:thumbsup: :D
  • waynus
Posted November 27, 2006 - 11:26 AM
So when you rebuild the engine with a big bore and crank kit would be the ideal time:thumbsup: :worthy:
Don't stop worrying yet Boer.
Maybe if the chain is replaced at say 10,000km, it wont hook the sprocket:excuseme:
