650R pilot
5 replies to this topic
  • motopsycho650
Posted November 24, 2006 - 06:25 PM
Because I cut out the side panel covering the air filter, I had to re-jet. Now, the mixture adjustment screw has to be set at 3 1/2 turns out with a 68S, (seems like the screw could be too loose and eventually fall out). I have tried a 70S, and it works great at 1 turn out. The only issue with that is, I don't have much adjustment room to go leaner when I get higher in altitude.
Keep in mind, the adjustments amounts are max values for my lowest riding elevation. I live in CO, so as I go up, I have to adjust the bike leaner.
What would you use? Is it okay to run the mixture screw at 3 1/2 turns out with the 68S? Would it be worth trying a regular 70 pilot jet? I've heard I'll lose some of the low end "hit" if I use a non "S" pilot jet.
  • vaughn
Posted November 24, 2006 - 06:43 PM
3.5 turns is too far out. Put a plain 70 in it. Should be between the 68s and 70s and put you at 2 turns out.
  • weskc35k
Posted November 24, 2006 - 07:05 PM
I'm with Shaun on this one.
  • motopsycho650
Posted November 25, 2006 - 08:41 AM
I threw a regular 70 in last night. I'm hoping the sun lasts, and I might go dial it in today.
  • motopsycho650
Posted November 27, 2006 - 06:52 AM
I think the 70 did the trick. 2 turn out, just like you said. It has all the low-end power that the 68S of 70S did. Thanks.
  • hypersthenos
Posted November 27, 2006 - 09:41 AM
That's good info. Thanks motopsycho650 for posting the results.
Honda XR650L 2017
  • 0 reviews
Fell Off Trailer by usafxr
  • Hot  43 replies
  • 17 replies
  • Hot  35 replies
