Nx 650 Front Wheel For The L
1 reply to this topic
  • frankiewhipit
Posted November 22, 2006 - 04:31 PM
Has Anyone Tried To Swap The Front Wheel From An Nx650 Onto A Xr650l? As Best As I Can Tell The Inner Bearing Bore Is Smaller (15mm), Other Than That, I'm Thinking It'll Work.
  • frankiewhipit
Posted November 30, 2006 - 04:06 PM
OK IF ANYONE IS INTERESTED, IT DOES WORK, YOU HAVE TO CHANGE THE BEARINGS TO THE XRL BEARINGS WHICH ARE 1 MM THINNER, MACHINE A SPACER FOR THE ROTOR SIDE, 20MM WIDE INSTEAD OF 19MM & PUT A 1 MM WASHER ON THE SPEEDO DRIVE SIDE:thumbsup:
