xr600r timing
1 reply to this topic
  • gixerkarl
Posted November 22, 2006 - 02:32 PM
i need to put my xr back together.....which way round does the cam go,lobes down or up????many thanks
  • cleonard
Posted November 22, 2006 - 02:39 PM
It doesn't matter. As long as the crank is at TDC and the lines on the cam sprocket are in line with the head, you are good to go. Just make sure and verify a few times that everything is right before going any further. It's real easy to get it one tooth off. After you get it on there, I like to turn the engine a few times to be sure that everything is lined up correctly.
Later in the process when you put the head cover on, it's easier if the lobes are down.
  • 3 replies
  • 17 replies
  • 9 replies
  • Hot  60 replies
  • 22 replies
