650R Pilot Adjustment Screw
3 replies to this topic
  • motopsycho650
Posted November 22, 2006 - 10:16 AM
Does anyone know where I can get a thumb adjustment fuel mixture screw for my '03 650R? My buddy got one for his WR450, and I think it would be cool, being I have to adjust my carb more often for elevation.
P.S. I finally got around to cutting out my left side panel. I did the whole screen & rivets myself. HOLY SH*T!!! People said it made a difference, but that is scary power now. I can't believe how much power you can gain on this bike with very little $$.
  • eastreich
Posted November 22, 2006 - 12:38 PM
The fuel mixture screws only work on the FCR carbs. They make them since the screw is under the carb and recessed in. Your stock XR carb has an easily accessible air screw on the side. No one makes a replacement for this since it is so easy to get to.
The circuits between the two carbs act differently. In the XR carb, you can tune the amount air going through the circuit. The fuel amount is fixed. On the FCR carb, the air flow is fixed and you adjust the fuel. It is a six of one, half a dozen of the other situation, but in a nut shell, if the adjustment is on the side of the carb (PE, PWK, etc...) it is an air screw. If it is on the bottom (underneath everything) as on an FCR, it is a fuel screw.
  • vaughn
Posted November 22, 2006 - 07:25 PM
It is a fuel screw. Kouba (same people that do the Kouba link) makes a T-handle replacement screw for about $20.
http://koubalink.com/fuelscrew.html
  • motopsycho650
Posted November 23, 2006 - 05:10 AM
No dude, you're wrong. It is a fuel screw. It's just a older design, not a new flat slide, pumper carb design.
  • 17 replies
  • Hot  35 replies
  • Hot  29 replies
Fell Off Trailer by usafxr
  • Hot  43 replies
