1992 XR600 Restored (PICS)
26 replies to this topic
  • Beerad
Posted November 21, 2006 - 10:24 AM
OK, guys, I recently finished restoring an old XR600 that was given to me from a friend after it sat in his garage for about 5 years collecting dust! One note about the pictures, this bike was complete ROACH when I got it, unfortunately I lost the before pictures though. And yes, it's CA plated!
Everything on this bike was either rebuilt, repainted, replaced, or refinished to perfect working condition. check it out. I've also recently bought a Garmin Etrex Vista CX and the RAM mount for the bike and am curious about adding a 12v accessory plug for it, is this possible on this bike since there is no battery?
thanks,
  • SniperTeamBravo
Posted November 21, 2006 - 10:35 AM
No, you need not only a battery, but a rectifire regulator to change AC current comming out of the stator, to DC for the accessories, and regulate it. Having a battery is a good thing for many reasons. One is the lights work without the motor running, and won't dim at the stop signs or stoplights. And the other is all 12v accessories will also work and not fry, and will continue to work without the motor running. The changeover is easy, go to Baja Designs website and buy a DC rectifire regulator, run the white/yellow AC wire into it from the stator after removing the stock AC regulator from under the seat, then go to Batteries plus and buy the long skinny 2.9AH Gelcel and wire the red wire from the rectifire to it on the hot side, ground the batteries black side and ground the black wire comming out of the rectifire. DO NOT ground these two tegether on and XR600 as it will not work. Ground both to the frame. Then run the power wores that used to come out of the AC regulator to the hot out on the rectifire and you are golden. Nice job by the way! The bike looks great....if you every want to sell it itll sell very quickly. How much time is on the motor?
  • Beerad
Posted November 21, 2006 - 10:42 AM
Great info on the electrical sniper! I'll keep that in mind if/when I decide I need 12v power supply.
I rebuilt the motor a few years ago before my friend stopped riding the bike so it's fairly fresh. Has good compression and runs strong. It's funny, after the restoration, the bike fired up first kick after not being started for over 2 years!:cheers:
  • motivater
Posted November 21, 2006 - 10:50 AM
You Dont Get Any Better Than That!!!!!!!!!
  • ganshert
Posted November 21, 2006 - 11:11 AM
You don't need a battery to get quality filtered 12VDC out of your 12VAC setup. Unless you need DC power with the bike off (does your state requires the tail light to work with the bike off) or have electric start a battery is not required or in my opinion desired.
option 1; http://www.touratech...0021&=Find+Part
option 2; regulator/ rectifier and capacitor instead of regulator / rectifier and battery http://trailtech.net...03-RR-150W.html http://trailtech.net.../040-CAP27.html
both of these options are the same, r/r with capacitors to filter, #2 is better if you will be running everything (lights, turnsignals, horn, GPS, etc...) on DC, #1 is better / easier if you just want power for your GPS.
P.S. nice job on the bike, great attention to detail
  • BRPXL600R
Posted November 21, 2006 - 11:15 AM
Man that is done really great! I likey!!!!
  • Motosprtman
Posted November 21, 2006 - 11:44 AM
VERY NICE! the only thing missing for us old guys with bad knees is an e-start button.
  • BRPXL600R
Posted November 21, 2006 - 12:09 PM
AMEN BROTHER!!!!!!
  • Fetona
Posted November 21, 2006 - 12:14 PM
Looks Great!!! Now go out and do some thrashing on it :-)
  • rmhrc630
Posted November 21, 2006 - 12:18 PM
Man that is a nice restore!!!!!!!!! I reckon it looks better than the red version!!!! The work that has gone into that is simply sensational!!!!
BTW - here's my answer to electric start - XR600 motor converted to E start:
  • SniperTeamBravo
Posted November 21, 2006 - 12:24 PM
Two words on that first kick thing
Itsa Honda
  • Boy named sue
Posted November 21, 2006 - 12:25 PM
Nice try that's a 650l cool looking bike though what is the front end off crf 450?
  • TDC71
Posted November 21, 2006 - 12:28 PM
Terrific resto job, have fun tearing up the trails:applause:
Todd:thumbsup:
  • rmhrc630
Posted November 21, 2006 - 01:05 PM
Actually - it's an XR600. (mine)
Yes 2005 CRF450R forks, hub etc.
That 1992 bike is awesome - how did you get the motor looking so new?
  • Beerad
Posted November 21, 2006 - 02:45 PM
scotch brite pads and solvent tank for the motor. Good old fashioned elbow grease!
  • SniperTeamBravo
Posted November 21, 2006 - 03:14 PM
Or you can use a drill motor and a brass wire wheel. It is soft enough to not scratch the cases, but burley enough to take off all the paint and stains. Im going to do my Supermoto after I thro the USD forks and stuf off of the desert sled on it for the winter.
  • Owyhee
Posted November 21, 2006 - 10:12 PM
BRAVO! That bike looks brand new and it's soooo clean! It looks like I could eat off the motor.
Did you paint the stock header silver? If so, what type/brand of paint did you use?
"O"
  • frankstr
Posted November 21, 2006 - 10:42 PM
Looks Sweet...:cheers:
:p :bonk:
  • Bennito
Posted November 22, 2006 - 09:13 AM
I've got a 92 as well. I feel like such a slacker.
If creating a bike so clean that people on TT would drool - Well played.
  • Beerad
Posted November 22, 2006 - 09:24 AM
the header is ceramic coated from Big Gun, it came like that. then I just added a little reflective heat tape to keep from buring my pants.
Would a Young Scott Summers still be Competitive today on an XR600R? What would he ride to be competitive today? by Jayzonk
  • Hot  159 replies
  • Hot  60 replies
  • Hot  29 replies
  • Hot  35 replies
  • 3 replies
