The old wr starter removal thing (yz stator?)
4 replies to this topic
  • dumper_uk
Posted November 21, 2006 - 04:33 AM
I have a mint 04 YZ450 sat in the garage,and have recently broken an 03 WR450 so have the WR engine(bare engine-no starter etc) also sat in the garage.
I love the YZ chassis but find the motor is only any good for motocross.I am looking to build a hare and hounds/trail bike,It doesn't need lights,doesn't need registering.But it must be light,reasonably powerful and preferably have a 5 speed wide ratio box.
I don't mind kickstarting,If the bike is jetted right and you have the right technique,there is no reason for a bike to be hard to start.
So obviously I am looking at putting the wr motor into the yz chassis.
I have read all the posts about blanking the starter hole and using a battery eliminator.
Would I be able to use the stator/wiring/cdi from the yz? thus eliminating the need for the batt eliminator and starter plug.
Or would I need to use the stator/flywheel and casing from the yz?
I think with the standard wr cams and the yz carb/airbox etc it would make an awesome off road bike.
  • dumper_uk
Posted November 21, 2006 - 08:23 AM
OK..so I just looked at yamaha motor.com and checked the parts diagrams and I can see that I can't use the stator off the YZ.
Only problem now is that I don't have the wiring for the WR to use a battery eliminator..
any ideas on how I can do it?
  • Jackazz
Posted November 21, 2006 - 12:42 PM
I don't recall anyone mentioning that they've done it before, but maybe you can take the WR tranny internals & put them in the YZ motor? Could be worth a shot. You'd probably want to add some weight to the YZ flywheel as well.
  • Wasabi
Posted November 22, 2006 - 06:11 AM
PM "ncmountainman" he done it.....
  • ncmountainman
Posted November 22, 2006 - 07:31 AM
steahly offroad has all kinds of crap to make this possible and chuck(owner) is very helpful on the phone. basically you just need one of those battery replacement doojiggers. when i did it with my 04 wr i had the stock wiring and grounded the neg lead to the frame at the voltage reg and just capped off the + lead and was done with it,no battery or replacement doojigger. was it correct ??? i don't know but the bike still runs no problems:thumbsup:
