2007 WR450 Performance Mods
314 replies to this topic
  • DEZZNUTJOB
Posted December 26, 2006 - 05:10 AM
That lip is to hold the screw in case it vibrates out. Now that you added some weight and length to the fuel screw it would be a good idea to stretch the spring a tiny bit in order to give the screw a tighter fit. This happened to my 426 and stretching the spring did the trick.
  • dafyddroberts
Posted December 26, 2006 - 03:59 PM
Check this out ais removel kit for wr450f 2007:
http://www.powerpart...emoval-kit.aspx
  • clark4131
Posted December 26, 2006 - 04:18 PM
Wrong kit! The ones for the '05/'06 won't fit the '07...SC
  • moki01
Posted December 26, 2006 - 05:06 PM
I just got the 07 WR 450 and it's my first 4 stroke. What are the mods needed asap? It feels pretty plugged up for a 450.
  • Derwud
Posted December 26, 2006 - 05:22 PM
Yamaha should have AIS kit out in Jan. Until then, you can cut down the throttle screw or get a YZ screw. Open up the exhaust. 48 or 50 pilot jet.
Oh and do a search.
  • arizonachef
Posted December 26, 2006 - 07:27 PM
well just got back from my first real ride on the bike 106 miles. It is a great bike it rips and top end is unreal. i have done all free mods. my only problem was i blew my fork seal.
  • clark4131
Posted December 26, 2006 - 08:26 PM
Read the Newbie Sticky!!!!...SC
  • b_faster
Posted December 28, 2006 - 12:55 PM
I have gotten the following done to the WR:
Carb screw shortened
Air box opened
Inner tube in exhaust removed
Grey wire disconnected.
I started after the jetting last night, I removed the rear subframe, exhaust, shock for access. This is not a two minute job. :lol: I have a JD kit and a fuel screw on the way, however I am not sure when it will get here. I am debating on putting this back together or just waiting for the kit. I have the 170 main and 48 pilot in.
Does anyone think the spark plug is changeable with the engine in the frame?
Is there a better way to access the carb as opposed to removing all of this hardware?
The vent on the starter, what is its purpose?
I need to lighten this bike for racing, any ideas?
  • msgbean
Posted December 28, 2006 - 01:01 PM
Yes the engine is changeable with the engine in. You just have to remove the gas tank. I assume you have an 07 so removing the shock is the easiest way to work on the carb if you need to remove the bowl but you don't need to remove the subframe. The hose on the starter is the crank case breather.
  • b_faster
Posted December 28, 2006 - 07:09 PM
Yes it is a 07, I just recieved the manual and plug wrench today. I didnt get it when I picked up the bike that is a long story. I was distracted with the other bikes being picked up. I am going to attempt to remove the plug tommorow. I am also removing the AIS I need to get some plugs.
  • cksea
Posted January 02, 2007 - 11:25 AM
When I bought my 07 I had the service department handle the AIS and jetting, 50 and a 170. The service guy said that he plugged up the hoses but did not remove it. Does that work? It still pops bad on decel, is that the air/fuel screw or is the AIS not blocked off? Any ideas?
  • Derwud
Posted January 02, 2007 - 11:30 AM
I would try the fuel screw as long as everything is blocked off on the AIS..
  • msgbean
Posted January 02, 2007 - 11:38 AM
That sounds like a half-ass job to me. If everything is blocked off then remove the two screws and get rid it. My guess is that it is still there because they they don't have an 07 kit and didn't have anything to block the exhaust port so they just blocked the hose connections. If the hoses are just laying there it is still going to suck air (dirty air).
  • cksea
Posted January 02, 2007 - 12:06 PM
There is a plug in the small hose, not the larger one by the header. I think I need to just pull it off and plug it up. The carb is drilled out to get to the air/fuels screw its almost impossible to adjust without rotating the carb, will a aftermarket $20 screw fit in there.
  • msgbean
Posted January 02, 2007 - 12:34 PM
Yes, or you can make one like on page 2
  • hcardenas
Posted January 02, 2007 - 01:09 PM
Will an 06 YZ450 aftermarket slip on exhaust fit for the 07 WR450? Will the full system fit as well? Also, will an 07 YZ450 fit and 07WR450? Any clues??? Thanks!
  • SJMC_DON
Posted January 02, 2007 - 03:01 PM
Has anyone looked hard at the radiators?
Is the cooling system identical to the YZ's? Those YZ Rads look way to small to keep this beast cool in the tight and technical that ride up here the PNW. They also look as if they would not hold up very well to an impact, side or front.
If they are the same as YZ rads does anyone know if Fluidyne has a set made up yet? (Yes, Clark I know I'll check the website:busted: ). How bout a good set of Guards yet, anyone if flatland, rooster or anyone else have a set yet?
Thanks guys! Hopefully by the time I get mine in March everything will be figured out for me:applause:
  • 520Roost
Posted January 02, 2007 - 04:01 PM
yes they will fit ,u just have to use the pipe donut off the inside of the 07 wr muffler.:lol:( the header on the wr is smaller )
  • msgbean
Posted January 02, 2007 - 04:02 PM
The WR radiators are actually larger than the YZ. One or two extra cores I think. I don’t know of many radiators that do hold up well to impact but at least they have attempted to strengthen them with the built in braces.
  • Island Boy
Posted January 02, 2007 - 05:25 PM
I dont know about a slip-on but TT member Derwud2 installed a 2006/2007 YZ450F full DR.D exhaust system on his 2007 WR450. He said it fit better than the factory exhaust. I bought the same set-up for around $400. Unfortunately it is sitting in my garage waiting for the bike to arrive on the 18th.
