Won't Idle without choke on
12 replies to this topic
  • rvankirk
Posted November 20, 2006 - 01:51 PM
My 2005 bike has never wanted to idle well.I had the valves adjusted and carb cleaned.It has set for 5 months now it will not idle at all if you tunn the choke off.
  • DesrtRyder7
Posted November 20, 2006 - 02:00 PM
Try adjusting your idle screw and let it rev higher. That's what usually does it for me. Just so you know, the idle screw should be on your carb, or at least it's on my carb.
  • rvankirk
Posted November 20, 2006 - 02:14 PM
The rpm's have to so high it not reasonable to leave it there.
I wonder if something could be plugged inside the carb ?
  • Throttlejockey
Posted November 20, 2006 - 02:28 PM
I bet you're pilot jet is plugged.
Remove the float bowl plug and take out the main and pilot jet.
Clean out the jets with carb cleaner and spray out the jet orifices too.
Be sure you can see light through the pilot jet.
  • cpr1
Posted November 20, 2006 - 02:29 PM
Your pilot jet is clogged. The carb does NOT need to come off, you can rotate the carb just enough to get the bowl off and access the pilot jet.
Hope that helps.
  • Throttlejockey
Posted November 20, 2006 - 02:34 PM
Hope that helps.
The bowl doesn't need to come off either, just the plug.
  • rvankirk
Posted November 20, 2006 - 02:54 PM
Thanks
  • motox888
Posted November 20, 2006 - 03:07 PM
If that isnt the problem then you pilot jet is too lean, try stepping it up a couple sizes!
  • 40oz
Posted November 20, 2006 - 03:38 PM
my bike did the same thing, it was the valves. they went out of spec. remember once you adjust them you are on borrowed time. cant hurt to check the clearances again its quick and easy to do. (and will kill off an item on the check list)
  • cpr1
Posted November 21, 2006 - 09:50 AM
True, the bowl does not need to come off....unless he has some junk floating around in there.
  • Heckler
Posted November 21, 2006 - 10:25 AM
Or your cam timing is off.. I know this happened to me once, Or make sure the hot start thingy in the carb is in all the way, sometimes that spring gets bound up and the plunger wont seat, it will feel fine at the lever bit it's not.
  • SpdTrip
Posted November 21, 2006 - 04:18 PM
i had the same thing happen and it was the main jet. i cleaned out the main jet and everything was good as new.
  • CRF_250_X
Posted November 22, 2006 - 03:56 PM
The exact same thing happened to my 04 twice there is probably a really smal dirt particle trapped in your idling circuit
2015 CRF250X First Ride by adamaveal
Dirt Bike   Make / Model Specific   Honda   CRF250X
  • Hot  28 replies
2006 Honda 250X Jetting Issues by MNThumper250
  • 21 replies
Honda CRF250X 2017 by Chris.GVS
Honda CRF250X 2017
  • 0 reviews
Honda Crf250x mods by Son_of_harry14
  • 6 replies
Honda CRF250X 2016 by Chris.GVS
Honda CRF250X 2016
  • Last review by toppo72
  • On November 28, 2016
