05 Wheels on an 06?
3 replies to this topic
  • Climber
Posted November 18, 2006 - 06:37 AM
Will the 05 wheels (hubs) swap right over to an 06 without any mods/shims?
I got to wondering after the thread on th 04 trees stated that the fork spacing was 2mm narrower.
Got good torque wrenches, dial indicators, Starret micrometer set,evne a truing stand for pre- 1970 Harley big twin fly-wheels,... but can't find my stinkin ruler... time to clean the garage or head to the hardware store...:cheers: :p :bonk:
Thanks
  • ethan
Posted November 18, 2006 - 06:58 AM
Yes they will. The spacer are a different shape to help put the wheel on, but the hub is the exact same.
Posted November 18, 2006 - 09:06 AM
You need to read it a little more thoroughly:
... The fork tubes are set 2mm farther apart. They made it possible to use the same wheel/axle/spacers by setting each axle lug inward 1mm to compensate for it.
  • Climber
Posted November 18, 2006 - 12:16 PM
Thanks
I measured every thing up and found out the right way.
