Oil Drain Plugs???
2 replies to this topic
  • Jekel
Posted December 23, 2001 - 12:52 PM
Has anyone had trouble with the engine drain plug and frame drain plug? I bought a torque wrench for these and when i go to torque them, it seems as though I'm putting WAY TOO MUCH pressure on the bolts. The torques are 14# engine bolt, 7.2# oil filter bolts, and 17# frame bolt. Do you think it might be the wrench? It is brand new???? Any info would be appreciated :)
  • CY_in_CA
Posted December 23, 2001 - 02:58 PM
Sounds like a bad wrench. Can you try another one? 14 lbs should feel like over tightening.
  • CY_in_CA
Posted December 23, 2001 - 03:01 PM
Ooops...I meant that it shouldn't feel like you're over tightening.
