Maintenance intervals
2 replies to this topic
  • MJC476
Posted November 17, 2006 - 04:25 PM
I know this has been asked a heap of different ways before, but.... I would like to know how long (in hours) you should run between replacing/rebuilding the following parts without doing un-necessary work or pushing the use by date too far.
Piston Rings
Piston (& rings)
cam chain (& bottom sprocket?)
split cases & check/repair bottom end & gearbox
There is enough info on valve monitoring adjusting out there, but any other component you may think is important to replace regularly.
Thanks:thumbsup:
Posted November 17, 2006 - 04:47 PM
It's tough to guess at the hours, but I'll guess that I put on about 75-100 per year. But only about a third is racing. The rest is hard recreational riding.
In that environment, a new cam chain annually is about right. You do not want to replace the bottom sprocket; it's cut directly on the crank. You can figure out what that means, right?
As to the rest, I have to say, I don't know. My '03 has had nothing more than oil changes and two cam chains since it was new. Original rings, original piston, never a valve adjustment. I'll say that it might be a good idea to re-ring it soon.
  • MJC476
Posted November 18, 2006 - 06:51 PM
Thanks Gray,
A cam chain every 100 hours & might as well wack a set of rings out of the spares kit in at the same time. That won't be too taxing on the wallet or time.
  • On January 15, 2017
  • 0 replies
  • 5 replies
  • Hot  28 replies
