losing fuel mixture screw!
6 replies to this topic
  • xr650l bum
Posted November 17, 2006 - 02:48 PM
xr650l. I have lost one mixture screw already. I dont want to lose another. It seems that when the tab is cut off it now enables the screw to rotate freely and then completely out!!! I am trying teflon tape to make it tighter, even stretching out the spring to give it more force. What to do, and where to get another just in case?
  • CTXr650L
Posted November 17, 2006 - 08:00 PM
i noticed the mixture screw on mine rotating out also, i put a zip tie around the head of it so that the tab of the tie hits the carb body keeping it from coming all the way out.
  • goblin127
Posted November 17, 2006 - 09:02 PM
When I still had my stock carb on I was only running 2 turns out and it was nice and snug. Try a dab of permatex on there.
  • XR650L_Dave
Posted November 18, 2006 - 02:33 PM
If its loose, make sure that the spring, metal washer, and o-ring are all in there, and in the right order.
Dave
  • Jon-D
Posted November 18, 2006 - 06:13 PM
I had a similar problem with my KTM and the only solution is to replace the spring. Over time, the spring looses it's tension and eventually allows the screw to vibrate out. I tried stretching the original spring and it lasted a little longer, but eventually the screw fell out. After I replaced the spring, no more problems.
  • luissuperdog
Posted November 20, 2006 - 09:44 AM
Yes new spring will do the job
I had similar problems and it help
  • mperry70
Posted November 20, 2006 - 12:54 PM
Unfortunately you cannot order a fuel screw from Honda. The part does not even show on the fiche. Junkyard or new carb seem to be the only options.
  • 9 replies
Honda XR650L 2017
  • 0 reviews
  • Hot  29 replies
  • 22 replies
