Is a Front wheel on an 05 Yz diff then my 06 WR?
3 replies to this topic
  • MountainMax
Posted November 17, 2006 - 01:42 PM
I wanted to remove my stock speedo drive and put in a spacer from a last year YZ and run an aftermarket Vapor speedo (with tach). Someone told me the front wheels are different and it wont' work, has anyone sized it up or tried this??
  • SID013
Posted November 17, 2006 - 04:19 PM
Hi Mountain, I was looking at doing the same but just so I could have a set of road type tyres for on-road use then just swap over to my wheel with knobbies for the weekend. I checked out this website & they have all OEM part numbers so you can compare part numbers. It appears the rear wheels are the same right back to about '02 but the fronts change from '05 on. Check it out & compare the part numbers. http://www.bikebandit.com
Cheers
Pete
  • BlueBlood Rider
Posted November 18, 2006 - 10:31 PM
WR front hubs are different from YZ hubs. Barnum Pro used to make a speedo drive eliminator for the WR, but he hasn't made them in over a year.:cheers: You can use a YZ wheel on the WR so long as you use all the YZ spacers.
  • MountainMax
Posted November 19, 2006 - 11:43 AM
Well I guess I may have to leave it in there then, no biggie....
