06 Forks
5 replies to this topic
  • crfrookie
Posted November 11, 2006 - 08:20 PM
What forks can be interchanged in a 06 450? I am going to ice race this year and I don't want to chop my o6 suspention, so I thought I would get a spare set of forks? Not sure if this is the way to go or not? Are all YZ forks interchangable, or is there a specific year that I should try to get for ice racing? Thanks for your help.
  • NOMADAK
Posted November 12, 2006 - 10:49 AM
The entire line of 2004 Yamaha YZ models recieved larger diameter 48mm forks. Unless you are going to change out triple clamps as well as the forks, keep this in mind when you go looking.
  • riderman329
Posted November 12, 2006 - 04:56 PM
the 04 forks are completely different then the 05 or 06 there is now twin chambers in the 04 unlike the 05 and 06 models
so try finding a for off and 05 or and 06
  • NOMADAK
Posted November 12, 2006 - 06:41 PM
The internals may be different but the outer diameter of the forks is the same since '04.
  • riderman329
Posted November 12, 2006 - 07:13 PM
ok... i don't think it would be a problem using an 04, but keep in mind that the fork caps on the 04 are completely different then the 05 or 06
Posted November 13, 2006 - 10:21 AM
The triple clamps on an '06 are set 2mm farther apart than earlier model 48mm forks ('04 & '05). This is made up for on the '06 at the bottom of the fork by moving the axle lugs in 1mm each so that it can use the same front wheel, etc.
You could use either the '04 or '05 forks in the '06 clamps IF you add a 1mm washer between each fork leg and axle spacer, one on each side.
  • Hot  30 replies
  • 10 replies
  • Hot  36 replies
  • Hot  113 replies
  • Hot  47 replies
