HELP!! Fuel screw O-ring
10 replies to this topic
  • sdc
Posted November 11, 2006 - 02:09 PM
I pulled a BONEHEAD move and lost the fuel screw o-ring!:cheers:
Does anyone know the dimensions? Or Do I have to endure further humiliation and order anthor Yamaha screw w/O-ring.
Suggestions??
  • Indy_WR450
Posted November 11, 2006 - 02:54 PM
Make sure it is still not jammed up in the carb. :cheers:
Make sure you get a Buna-N 70 Durometer O-ring that is fuel resistant.:bonk:
The size is standard 3/16" O.D. , 3/32" I.D. x 1/32" thick. ( also referred to AS568A - 001 size ) :p
  • Dieselox4
Posted November 11, 2006 - 02:56 PM
what kind of bike is it?
mike
  • sdc
Posted November 11, 2006 - 03:06 PM
No its not still in carb. Checked several times w/light hoping it would appear.
And the bike is a 05 WR450F
Thanks for the quick replies
  • Dieselox4
i just replaced one yesterday in a 2004 wr450 and a 2002 ttr250. actual size (inch) is: 0.145 X .070 . normal size: (inch) I/D 5/32 . O/D 9/32 . Section 1/16. i hope this helps. just take those measurements to a place where they sell o-rings. i bought an o-ring kit awhile ago that has 30 different sizes and 20 of each size. it has saved me a few times. it was around $10 i believe.
mike
  • Indy_WR450
Posted November 11, 2006 - 04:02 PM
My new spare with fuel screw still in the original yamaha bag measures the above size.:cheers:
  • MountainMax
Posted November 11, 2006 - 04:27 PM
you can't buy one directly from yamaha listed for your bike, they want you to buy the whole screw/spring/washer/oring, but if you look up a 450f Quad, they show the parts seperately and you can pick one up at the dealer, it's not embarassing, as these dam screws come loose on their own and we end up losing them anyhow.
  • BajaFool
Posted November 11, 2006 - 08:52 PM
The part number for the o-ring from a 2006 YFZ450S ATV is 3TJ-14562-40-00 (see carb picture at Yamaha USA item 51). On-line price at http://www.mrcycles.com/ is $1.24. Did you lose the little washer also? It is item 52 in the picture and the part number is 3TJ-14952-40-00. I didn't check for an on-line price, it can't cost much.
  • sdc
Posted November 12, 2006 - 12:55 PM
Back on trail:applause:
Thanks for the help!
Local dealer didnt have Yamaha part# (for o-ring) but did have Keihin o-ring assortment w/ a 2.5 MM ID X 1.15 MM Thk, very close to INDYS specs.
BTW w/o the o-ring in place the bike "pops" A LOT on decel.(lean)
Thanks again all, THIS SITE RULES!:cheers:
  • WR_Dave
Posted November 12, 2006 - 02:48 PM
Check www.stealthracingtech.com they have an o-ring,spring,washer kit for $5 WR Dave.:cheers:
  • 5hauler
Posted November 14, 2006 - 01:26 PM
The same carb is used on the 450 Suzuki. I get mine from them and there normally in stock.
Jay
