grey wire
11 replies to this topic
  • davo ttt
Posted November 10, 2006 - 05:02 PM
:cheers: want to know if i cut the grey wire will i have to alter any carbie settings or anything else on a wr 450 06
  • WR_Dave
Posted November 11, 2006 - 07:12 AM
Not if your jetting is good already . WR Dave
  • Dan_Lorenze
Posted November 11, 2006 - 07:46 AM
You should correctly jet your bike and also cut the grey wire.
Do the Euro WR's even have grey wires?
  • MountainMax
Posted November 11, 2006 - 11:41 AM
I done mine, with the other free type mods and Indy's jetting, and it's all good stuff, worth doing.........
  • ferguscawley
Posted November 11, 2006 - 01:03 PM
Yes they do. My '06 450 has/had one.
Earlier European / UK model 400s did not.
  • OneToGo
Posted November 11, 2006 - 08:38 PM
YES, the EURO version has a grey wire - its fitted to all the 06 versions at least.
The only appreciable difference with the EURO version is lighter springs, YES, the AUSSIE and USA gets stiffer springs. The std damper settings are altered accordingly. All else is pretty much the same.:cheers:
PS. sorry fergus I did not see your reply...
  • davo ttt
Posted November 11, 2006 - 11:12 PM
thanks all :cheers:
  • Thermos O flask
Posted November 12, 2006 - 07:01 PM
Do aussie wr426's have a grey wire to disconnect?
  • WR_Dave
Posted November 13, 2006 - 06:38 AM
Yes it is in the plug under the tank. Check thumperfaq.com it is the same on the 250 so the info is valid. WR Dave
  • MerlinUK
Posted November 13, 2006 - 07:16 AM
My 03 wr450 has a grey wire (UK Model). I have disconected it.
  • Thermos O flask
Posted November 13, 2006 - 07:36 PM
Thanks for the info
  • GCannon
Posted November 14, 2006 - 09:57 AM
It is my understanding that the Canadian and Aussie 426 versions are the same. My Canadian version Did Not have a grey wire. It also comes with a differnt Needle and YZ throttle stop.
Hope this helps.:cheers:
