650r-ticking noise
8 replies to this topic
  • smrich
Posted November 10, 2006 - 04:51 PM
I have a 2000 650r Motarded. After a hard top speed run the top end started ticking bad the next day. First I replaced the cam chain tensioner, still ticking so I checked valves, adj. an still ticking! Ticking is in the top end. Should I be looking at the decompression? Would this be more like a bent valve or cracked spring? Bike still has all the power of before an doesn't smoke, but tail of muffler has a little black soot around it. Thanks guys!
  • BRPXL600R
Posted November 10, 2006 - 05:15 PM
How are the cam bearings? Do a compression check to eliminate bent valves.
  • smrich
Posted November 10, 2006 - 05:30 PM
Going to get tool. thanks
  • BRPXL600R
Posted November 10, 2006 - 06:09 PM
Your quite welcome!
  • frankstr
Posted November 10, 2006 - 11:58 PM
Welcome to Thumpertalk, smrich......
If it still runs good, no valves are bent and I dought you have a cracked spring...
From what you said, the valve lash is right..so it must be chain or ...:cheers: ...
:p :bonk:
  • XRMANU
Posted November 11, 2006 - 02:32 AM
Low oil level? -> worn rockers/cam :cheers: Worn rockers make some ticking noise.
Look also for brass in the oilfilter/screen....
  • smrich
Posted November 11, 2006 - 09:14 AM
Intake rocker arm really worn! Exhaust ok. Have to check spec on all parts, but if the intake rocker arm is worn am I looking at valve bent or springs cracked or shot, or camshaft out of spec? Maybe just the rocker arm is bad?
  • BRPXL600R
Posted November 11, 2006 - 12:27 PM
Well at least you found the tick! Congrats!
  • XRMANU
Posted November 11, 2006 - 04:00 PM
Check your oil level often ,especialy with high speed/Sm riding .Look out for your big end !
  • Hot  60 replies
  • 22 replies
  • 9 replies
  • Hot  35 replies
