Stator Output: wr426f ???????
6 replies to this topic
  • dbleon
Posted November 08, 2006 - 10:40 PM
Anyone know the stock wattage output on a 2001 wr426f??? Im looking to fit a battery, but supposedly i need at leased 75 watts... Any input is much appreciated! Thanks
  • jim-in-so-ore
Posted November 09, 2006 - 06:22 AM
If my memory is still working somewhat correctly it seems like the WR 426 stator put out 120 watts. I installed a 426 stator on my WR 400 because it only put out 80 watts. This was over 5 years ago so I could be off a little a on the wattage but I know that it is way over 75.
Jim
  • NuckingFuts
Posted November 09, 2006 - 08:15 AM
120w is correct
  • rdb
Posted December 18, 2006 - 10:26 AM
Jim
Is this right?A higher output 426 stator WILL bolt right in to a wr 400. Also do you have to change the flywheel as well?
  • jim-in-so-ore
Posted December 18, 2006 - 11:30 AM
RDB,
Yes, the later model stator is a direct bolt in. And Yes the flywheel is also the same. (all WRs of course) I got my stator from PowerSports Pro back when I did this (about 2001 or 2002) as they were the cheapest but maybe the ThumperTalk Store can beat their prices.
Jim
  • SXP
Posted December 18, 2006 - 12:15 PM
RDB,
Jim
Jim - did you also have to swap out the regulator (attached to the left side of the steering neck stem) to handle the extra output?
  • evilinsano
Posted December 20, 2006 - 09:38 PM
I don't think the regulator would need to be changed. All it regulates is the voltage and not the current. I think it can handle the little extra current supplied.
