do big bores overheat?
11 replies to this topic
  • yzsurfer
Posted November 08, 2006 - 02:15 PM
My tired '00 426 just blew 3rd gear. I'm tearing the engine down to fix this and will be doing the top end while I'm at it. I'm leaning towards the Eric Gorr 440 with hot cams and mild head work.
Has anyone had (or heard of) over heating issues with the big bore kits? I can't find anything in the past threads.
Thanks,
Jeff
  • Supafreak_711
Posted November 08, 2006 - 02:20 PM
I dont have any experience with yamaha's, but my riding buddy has a CRF470R which doesnt have any noticable overheating problems. At the GMB V race we waited at the bottom of a jump for the 393 bike to pass (Motoman393's bike) and we were both sitting next to eachother with our bikes running for a minute or so after the bikes were hot from running a 6 lap race (long laps). I'm not sure what coolant he is running, but I know that mine would have boiled over if I didnt have engine ice in there. I my 450 has boiled over several times in the past (mostly durring slow woods riding) before adding engine ice, so I am comfortable with saying that it works pretty well.
Hope this helps :cheers:
  • YZ250F_Rider
Posted November 08, 2006 - 04:28 PM
It depends on whether the overbore uses a high compression piston or not. Some of the bigger overbores use a low compression one and heat isnt an issue. some use high compression ones and heat can be an issue if the cooling sytem isnt in good shape.
  • 642MX
Posted November 08, 2006 - 05:15 PM
A big bore 426/440 shouldn't get any hotter than a stock 426. They all boil over if you don't get air thru the radiators.
  • yzsurfer
Posted November 08, 2006 - 06:25 PM
Thanks guys,
I hadn't heard anything about temps being a problem but the thought crossed my mind yesterday so I thought I'd post.
Anybody know if rejetting is required?
Thanks,
Jeff
  • YZ250F_Rider
Posted November 08, 2006 - 07:45 PM
always rejet when modding. From what I can gather the jetting tends to go a bit leaner with the overbore.
  • Ga426owner
Posted November 08, 2006 - 07:47 PM
My 470 has been ok with stock radiators so far...but fluiddyne and PWR make nice larger ones..do it do it do it big bore......
  • odlaw19
Posted November 08, 2006 - 09:06 PM
426 have pretty big radiators.
As said, check jetting.
  • Chazlom
Posted November 08, 2006 - 09:47 PM
I ran a 470yfz with head work , hot cams and a 13.5:1 piston without any problem ever for over three years. I have run my bike hard from Glamis to the High Desert races and overheating was never an issue.
It was a great bike, check "my garage". :cheers:
  • Ga426owner
Posted November 09, 2006 - 08:22 AM
past tense....Chaz? Did you sell that beast?
  • Chazlom
Posted November 12, 2006 - 09:28 PM
Yep.......three weeks, 10 hours and 26,1/2 minutes ago!:crazy: :worthy: :eek: :p :p :bonk:
Just got back from Glamis with my new bike all tricked out. Just got the 06 Husky 450, frame powdercoated, Suspension work on by the best......and still....I wish I had the 03 YZF back.....Damn :bonk:
To the Kid that bought my bike, You'll never know what went into that bike....damn your lucky!:cheers:
http://www.gpkings.com/
Chaz
  • Ga426owner
Posted November 13, 2006 - 08:49 AM
Chaz
sounds like you regret selling it...I know what goes into it Chaz.....lots and lots of money.....same with mine.
