Better seat for longer rides-XR650R
5 replies to this topic
  • hypersthenos
Posted November 07, 2006 - 11:14 AM
Okay I'm fixing to get a GUTS tall soft foam & cover for my pig hoping it's the proper setup for that price range. Don't have the dough for a custom job. My concern is that I like the height of the stock setup (5'10" with 32" inseam). I'm hoping that the soft foam will compress to something close to the stock setup with my butt in place. Is the guts setup wider for more comfort? Looking for something that will be tolerable for all day dual sport rides. Anyone out there got any input? Thanks in advance.
  • pburke
Posted November 07, 2006 - 03:07 PM
make sure you get a power staple gun. I just did the tall soft conversion on mine and even though I used a heavy duty stapler, getting the stuff to go into the plastic takes some serious press/push effort. At least have a helper.
How's the thing work? It is taller than stock, but softer. Still reach the ground like before with my feet, but the seat is somewhat softer/wider. Have not put a lot of miles on it to actually be able to say it's better than stock, but it really should be. I am 6"2 with 34" inseam and am totally flat-footing my bike with that seat, however, I think I may have a little too much sag in the back.
  • hypersthenos
Posted November 08, 2006 - 12:28 AM
Thanks Pburke. I guess I'll take the plunge & try the Guts setup. BTW I've found that heating the seat base with a heat gun makes stapling much easier. Still requires more than the average stapler but allows the staples to fully seat. Appreciate your input.
  • pburke
Posted November 10, 2006 - 07:42 AM
I'll have to redo the cover so I'll try the heat gun (have only a hair dryer, but that'll be pretty hot as well). One thing I wanted to add is that for short folks the actual "getting the leg across the seat" height is definitely increased. It only compresses down to about normal height when you sit on it. The seat is not wider than stock until you actually put your weight on it and all that extra foam gets a little spread out to the sides.
Peter
  • InternalCombustion
Posted November 10, 2006 - 05:22 PM
Okay I'm fixing to get...
Come on, hyper, they don't realy say "fixing to get..." in Washington state, do they? You musta picked that up, growing up in the South. Whar-bouts? (I grew up in Taxes).
Anyway--on post--I'm also fixing to get that exact same setup. What I was planning though was to step-down the foam a bit, maybe an inch or so in the front. My. Main reason for stepping it is to give a bit wider seating surface for my poor butt.
I figger if I step a tall-soft seat foam an inch I should wind up with a stock height--only wider, by maybe an inch, inch and a half. That's my plan anyway. (Come to think of it, if I step it down I probably should go with a tall-regular, instead of a tall-soft...)
Anyway, for your purposes this would also give you a bit lower seat height. You might want to consider that, when you get ready to install it.
:cheers:
  • hypersthenos
Posted November 11, 2006 - 12:25 AM
Sounds like a good idea there InternalCombustion. I think I'll stick with the tall, soft foam & try it as is & modify later if needed. I'll let you know how it works if mine's done first. BTW I grew up right here in "Warshington". Guess I've watched "Ol' Yeller" a few too many times.
