How to detune a CRF150R for wife/woods
Posted 07 November 2006 - 10:24 AM
IT IS A BEAST!
This is not a bike for inexperienced or timid riders and probably not well suited for woods either. It is a handfull and it will try to put you on your ass any time you slam the throttle hard. The dreaded "Honda bog" is there making slow transitions hard and it is LOOOOUUUUDDDDD!
I would never though that I would be considering taking performance away for a motorcycle but this bike is intended to replace my wifes CRF150F and I know that I am going to have to tame this little rocket a bit.
Here are some of the mods that I am considering:
-Heaviest flywheel weight available (Stealthy does not make one yet)
-Restricting the intake( getting creative with the air filter or carb)
-Restricting the exhaust( corking it?, excessive blowby concerns me)
-Using low grade fuel (87 octane or other)
-Decreasing compression (by any available means, more blowby concerns)
-Messing with the timing or any kind of electronic modification
-Getting a lame cam
-Going to a heavy chain (520 kit) and changing ratios (sprokets)
I know that this is a subject that will be on the minds of many husbands and parents out there considering owning this bike so please put your 2 cents.
Posted 07 November 2006 - 10:36 AM
Posted 07 November 2006 - 12:20 PM
ben
Posted 07 November 2006 - 07:04 PM
Posted 07 November 2006 - 07:05 PM
ben
Posted 07 November 2006 - 08:33 PM
Hey Ben, what is FWW?
Also I would like to say that going with a heavier head gasket was a very creative idea. I guess the thing on "detuning" is to think on reverse. One of my first impulses was corking this puppy but I am concerned that added back pressure could bring valve issues or excessive blowby. Oh what the hell, I am cancelling any emissions I see and instaling a breather anyway, just havent got there yet.
Posted 07 November 2006 - 10:59 PM
Not sure but I would guess:
FWW = Fly Wheel Weight
Posted 08 November 2006 - 07:16 AM
ben
Posted 08 November 2006 - 08:57 AM
Posted 08 November 2006 - 03:14 PM
I guess unless this is some kind of a "stealth" program within the company, they dont have any plans to offer these anytime soon.
I have not had the oportunity to see behind the case cover yet but there does not seem to be a lot of real estate inside there. I wonder how difficult this is going to be.
Well, there is always the local machine shop. I guess I can cook me one.
Also, has anybody installed that pro circuit pipe. It is suposed to have an arrestor and to lower the noise output too. Any comments?
Posted 08 November 2006 - 03:41 PM
Posted 09 November 2006 - 11:58 AM
Posted 09 November 2006 - 12:15 PM
As far as the FWW, it looks that I will be going to the machine shop sometime soon.
Posted 10 November 2006 - 01:22 AM
If you can't wait for Steahly to come out with a fly wheel weight, which I'm sure he will, having met the guy, you could try a Google search on "Moose Racing" out of Colorado. A number of years ago I had them add welded on FWW's to an ATK 406 and Honda TRX250R four wheeler, both two smokes. The FWW is rebalanced after welding which is critical if you don't want the engine to shake apart. Not all machine shops have the capacity to balance FW"s so be careful and ask questions if you use a local shop. Lastly you could also consider having an exhaust header pipe torque stuffer ring made by a machine shop. This ring with a sleeve welded to it, which was commercially made for Yamaha 350 Warriors, fits into the opening of the header pipe, reducing volume and increasing back pressure. The result is more bottom end in the engine. You would have to play with the diameter of the ring/sleeve in order to get the power characteristic you want.
Posted 10 November 2006 - 01:40 AM
yz440e said:
Avoid using multiple head gaskets-this may cause head gasket failure-instead use multiple base gaskets if you decide to go this route to lower compression-they are under less internal pressure than the head gasket.
Posted 10 November 2006 - 02:39 AM
redrider305 said:
