Is it ok to disconnect the decompression Cable on XR 600R?
10 replies to this topic
  • Redlines
Posted November 06, 2006 - 05:44 PM
I just put on a new set of Renthal Twin wall bars on and I don't have room to mount my decompression lever. I never use it anyway and there is much less mounting area on the Twinwall bars so it has to go. Can I just remove my decompression cable all together or should I leave the cable on the head and just cut the cable right after where it mounts to the head so there will still be some pressure on the lever on the head?
Thanks
  • eastreich
Posted November 06, 2006 - 06:23 PM
As soon as you remove the lever all together is when you'll crash and need the lever to clean out the cylinder to make it start!!
Why don't you get a XR650R clutch perch that has the auto-decompressor lever built in? I'm sure that you could also get any of the aftermarket perches for a 450/250 that have a hot start lever built into them and make them work also. If you spent the money for twin-walls, another few $$'s for a different perch isn't going to be a deal breaker is it?
  • dangerranger21
Posted November 06, 2006 - 06:35 PM
i run mine with no decompression and have been for along time no problems here but to each is own...
  • Redlines
Posted November 07, 2006 - 02:21 AM
Hey Dangerranger did you remove your cable entirely and have the actuator on the head have no tension on it at all or did you leave the cable end on on the head?
  • cleonard
Posted November 07, 2006 - 10:11 AM
The actuator on the head has the return spring, so it's no problem to just remove the cable.
  • SniperTeamBravo
Posted November 07, 2006 - 12:34 PM
I agree with eastreich and say get a perch with a hot start lever or a stock XR650R clutch lever set up. You'll get into a condition at sometime and WANT the decompressor. In fact my 96 has so much compression I can't start it without the decompressor.
  • Redlines
Posted November 07, 2006 - 01:42 PM
If I ever have to use it I can just use my hand and hold down the lever on the head as I kick it over. Thanks for all the responses
  • LeadDoggy
Posted November 08, 2006 - 07:14 AM
I have never used my decomp. Never had any problems starting eeven after dumpin it. :cheers:
  • SniperTeamBravo
Posted November 08, 2006 - 08:56 AM
watch out it may be kinda hot!
  • dangerranger21
Posted November 08, 2006 - 03:46 PM
I just removed the cable, no problems... been dumped many times still kicked over like a good little XR should..
  • cheezy
Posted November 08, 2006 - 04:02 PM
Yeah.
