xr600 oil coolers options?
29 replies to this topic
  • mikyrc
Posted November 04, 2006 - 11:52 AM
Hi guys.
I'm upgrading my XR600 with a NX650 cylinder and a 10.25:1 compression WISECO piston. I'm also replacing the stock carburetor with the NX650 one to have smother throttle response.
So i want to add an oil cooler to help maintain temps were they should be.
I've seen those coolers on ebay, do you think they could work on the XR?
http://cgi.ebay.com/...39247&rd=1&rd=1
The coolers measure around 7.5in x 3.15in.
What do you think?
I've also found some stock XR250 oil coolers (those round ones that go under the headlamp.)
Do you think that those would be better?
Thanks guys.
  • LandSharkGT
Posted November 04, 2006 - 12:48 PM
XR400R OEM oil cooler mount to the frame neck just have to have the mount nuts weld on.
  • mikyrc
Posted November 04, 2006 - 01:35 PM
Thanks LandsharkGT.
I've been looking for used XR400 oil coolers on Ebay, but i didn't find anything. But i did find some XR250 ones.
Do you know if they're the same?
How much can a new XR400 oil cooler cost?
Can i buy it online somewhere?
  • LandSharkGT
Posted November 04, 2006 - 02:27 PM
New from Honda is $117.00
Try these micro fische:
http://www.everettpo...tion_detail.asp
  • xr500_89
Posted November 04, 2006 - 06:56 PM
im also customizing an oil cooler for my 600 getting all the stuff from xrp i guestimate around 100-140 for everything including fitting piping and oil cooler if interested email me and i'll give you specific costs after im done and give you exact measurments, and if you interested i could give you the place im ordering everything from.
  • LandSharkGT
Posted November 04, 2006 - 07:08 PM
Yes keep us all informed please!!!
Bill
  • xr500_89
Posted November 04, 2006 - 07:43 PM
will do oil cooler is coming in on wed
  • mikyrc
Posted November 05, 2006 - 04:39 AM
YEs please, tell us everything you can. As i'm From Spain, maybe i'll have to see if i can find the parts here or online somewhere.
But what about the XR250 i told you guys?
http://cgi.ebay.com/...23051049&rd=1,1
Is that cooler the same as the XR400?
If so i think i'll buy it.
Thanks.
  • thouk
Posted November 05, 2006 - 05:47 AM
Mikyrc,
That is the same cooler as the Xr400. The fittings are different on the Xr250 oil cooler compared to the one on the 400. I have the one from a 250. I am going to change the way the oil lines attach to it and mount it on my Xr650r. I wish you good hands on getting it mounted. Keep me informed I may copy you. Thanks, Tony
  • mikyrc
Posted November 05, 2006 - 06:17 AM
Cool, that's good news :mad:
I'll go ahead and buy one of those from a XR250.
I can find the correct fittings here for the stock cooler so i'll not modify it probably. Just a pair of braided steel lines and something to attach the cooler to the bike and GO! :mad:
Thanks to everybody.
I'll post pics too as soon as i can get one of those coolers installed.
  • xr500_89
Posted November 05, 2006 - 11:59 AM
hmm i would hold off on that until you see the one im putting togethor dimmensions make it fit much easier on the forks just under the headlight and makes it more an opportune place since it wont get as thrashed there
  • mikyrc
Posted November 18, 2006 - 10:08 AM
How is going your cooler installation?
I ordered an used one from ebay, hope i'll get it next week.
I also just finished the big bore swap on my XR. Now i'm still on the breackin period, so i can't force it very much.
I've gained some horses but nothing spectacular i think.:cheers:
I also wanted to put a XR650L carb but i couldn't install it. i'll have to buy the rubber adaptor that goes from the carb to the cylinder and maybe the one that goes from the airbox to the carb. As it doesn't fit on the stock XR600 ones.
Please Thouk and XR500_89 keep us posted about the cooler mods.
  • xr500_89
Posted November 21, 2006 - 08:46 AM
goes good its going on sunday ( only day i dont work ) so pics will be up afterwards
  • spidennis
Posted November 26, 2006 - 08:47 PM
don't know of any way to subscribe to a thread other than to post .....
I'm wanting to add an oil cooler to my WR250F, and doing searches,
keep us informed of your progress! thanks.
  • cbaranski
Posted November 27, 2006 - 10:45 AM
xr500_89
How'd that oil cooler come out? Looking forward to seeing the pics. i'm thinking about doing one on my 96 XR600R.
  • xr500_89
Posted November 30, 2006 - 08:30 AM
had to hold off stretched out my timing chain got a tourny this sunday so next week everything will be done
  • asf
Posted December 03, 2006 - 06:21 PM
+1, just did a fresh rebuild on my 89 and after spending this much money A $150 cooler is cheap insurance.
How much does the jagg go for?
  • mikyrc
Posted December 04, 2006 - 11:35 AM
Hi guys, i received the cooler but it seems that is a bit smaller than the XR400 one (25% less height). But is better that than nothing.
AS soon as i can have a pair of nuts welded to the frame i'll proceed with the installation. I'll probably use cooper tube and have the fittings be welded on it. I've looked for rubber or steel braided lines but they're too thick (the outside diameter is too big).
Hope i can finish it soon.
  • thouk
Posted December 04, 2006 - 04:36 PM
Hey Y'all,
After looking at the cooler that I have, from an xr250r, versus the cooler from the xr400r I have determined that they are different. But I guess y'all already know that. I received in the mail today the banjo fittings for my cooler. I picked up some tubing for the connection. I just need to go pick up some thin sheet stainless steel for the mount for the cooler. After that I will mount it up and run the lines. I think I will have mine done next week. Have fun, Tony
  • Jeff@TheQuadShop
Posted December 04, 2006 - 04:39 PM
Here is the way we use to make the SRC kit...
http://www.srcinc.net/html/cooler.html
