320 grit or 240 grit hone?
16 replies to this topic
  • fletchman919
Posted November 03, 2006 - 08:56 PM
Which would be better: A 320 grit flexhone or a 240 grit flexhone? I'm wanting to buy the 320 grit because I think it would do the job without removing any more of the plating than is necessary. But I have no experience in honing a plated cylinder and would like for someone to inform me. Also what diameter works best: 3 1/4" or 3 1/2"?
  • MRW
Posted November 03, 2006 - 10:47 PM
My trusty Eric Gorr books say use the 240 grit. You only hone cylinder for about 8 seconds wet with some oil. Don`t worry you will not damage the liner as it is extremly durable.:mad:
  • fletchman919
Posted November 04, 2006 - 06:16 AM
OK thanks. Does it matter between the 3 1/4" and 3 1/2"?
  • aikiman22
Posted November 04, 2006 - 07:27 AM
I used the 3 1/2 and it was a tight fit, you could easily use the 3 1/4. Go with the 240 grit.
  • dudeman67
Posted November 04, 2006 - 07:41 AM
I read that 240 grit is designed for cast rings and 320 is for molly rings. At least that is what Flex-Hone recommends.
  • Rich_Rohrich
Posted November 04, 2006 - 08:47 AM
A 3.00" flexhone @ 320 grit is the proper version to deglaze a stock sized bore for new rings.
  • fletchman919
Posted November 04, 2006 - 12:25 PM
Cool!
  • fletchman919
Posted November 04, 2006 - 12:26 PM
Which rings does the CRF have or do I have a choice? If so, which is better?
  • tl1000crf250
Posted November 04, 2006 - 06:36 PM
read about plateau honing, real interesting.:mad:
  • fletchman919
Posted November 04, 2006 - 10:35 PM
If I understood what I read, then platea honing is when you would hone in layers. For example, hone a cylinder with a 180 grit. Next hone over that with a 240 grit. Then use a 320 grit. If this is the proper definition, then I don't see where it would be practical. :mad: Because you rough the cylinder up, and then work to smoothen it back up. Maybe I misunderstand or maybe it just isn't sinking into my brain. Can someone clarify this type of honing process? I did a search, but nothing real informative came up.
  • fletchman919
Posted November 04, 2006 - 10:36 PM
Also, can someone tell me what kind of rings are in my bike?
  • a_gunslinger
Posted November 05, 2006 - 06:19 AM
Agree. I used one I bought oiff ebay and it worked great - quickly!
  • a_gunslinger
Posted November 05, 2006 - 06:21 AM
Not sure I understand the question. I assume you have a stock 250? If so, you have these:
Rings: #2 in picture
BTW, where in Ohio are you? Im in Cincy
  • fletchman919
Posted November 05, 2006 - 02:07 PM
Oh man, don't tell me that! I just bought a 3 1/4" 240 grit hone off ebay! I wanted to get the 320 grit, but I read more posts of people using 240 grit and decided to buy that one. Does it really matter a whole lot? I figured everyone that was using the 240 grit thought it would seat the rings better.
  • fletchman919
Posted November 05, 2006 - 02:12 PM
Dudeman67 said that the 240 grit was for the cast rings and the 320 grit was for the molly rings. I wanted to know what kind of rings were stock in a CRF250....I'm in Wilmington, about 50 mins northeast of Cincy.
  • aikiman22
Posted November 05, 2006 - 06:52 PM
Don't worry the hone that you purchased will work just fine. I used the same flex hone for my rebuild and it worked well.
  • fletchman919
Posted November 06, 2006 - 03:48 PM
Cool! Thanks!.... Anyone know about the rings? I'm just curious now. My repair manuel doesn't mention what they are made of. At least I couldn't find it if it does.
2004 CRF250R HEADLIGHT by fsmith1221
Dirt Bike   Make / Model Specific   Honda   CRF250R
  • 4 replies
Should I get a two stroke? by Daniel_Likes_Bikes
  • Hot  95 replies
Honda CRF250R 2017 by Chris.GVS
Honda CRF250R 2017
  • 0 reviews
Steam/white smoke coming out of crf250r by Seth McKenzie
Did I get a good deal?-2011 CRF250R by BTYZSquad
  • Hot  47 replies
