Big Bore or High Comp.
14 replies to this topic
  • wacker boy
Posted November 03, 2006 - 04:14 PM
I am looking to get somemore low end power with out losing a lot of topend. I already have the hotcams set up in and running a 14-46 sprocket ratio. what i am asking is what is some of the differeces between the to.
  • baha
Posted November 03, 2006 - 04:36 PM
14/46 is a 3.23
14/50 (stock)3.57
13/46 3.53
13/50 3.84
Go back to stock?
I always change out counters for what I am doing on any given day and it is part of my chain adjustment.
I loosen the back up and slide the rear tire forward I can change a counter in a minute and adjust the chain all in the time you adjust your chain.
I have a 13.14.15 and know they make a 12. Desert 14, Woods 13, SM 15
I also have a 51,50,42 rears- not as easy to change. RMC Final drive steel makes this affordable as well. All of these will fit both my bikes.
  • Alley Cat
Posted November 03, 2006 - 08:08 PM
The high comp piston will boost power everywhere.
The bigbore kit will boost torque, boost bottom to mid as well as some top, but generally fall off very quickly.
I went High comp piston route simply due to cost. I also got some hotcams because I was looking for heaps more top end. They haven't arrived yet, I am looking forward to installing them.
If I had more money (always the story...) I would have loved to get a big bore kit. I say since you already got hotcams, go the big bore kit! :mad:
  • MountainMax
Posted November 04, 2006 - 07:06 AM
is the hotcams intake cam very different then our stock ones? i changed my exhaust cam with a yz one for more power but the intake is the same on the YZ. I was also told that high compression will help out more on the bottom end then top end, and i too would change that back sprocket back to a 50 unless youre doing alot of high speed continous driving, that will give you more power also.
  • Alley Cat
Posted November 04, 2006 - 09:40 PM
Yes I believe it has more lift and duration most likely more.
Here is the hotcam intake cam specs, I can't find the stock specs.
Intake
Intake lift (mm): 8.86
Intake lobe center (degrees): 110
Intake duration (degrees at 1mm): 269
Intake valve lash (mm): .15
Here is gains over YZ cam set up:
http://www.hotcamsin...58693831348.jpg
Is it worth it. I don't know yet! :mad:
  • Alley Cat
Posted November 04, 2006 - 10:45 PM
What exhaust are you using?
A different header (longer) might do you nicely, such as a FMF powerbomb or megabomb. They will (if you get sx version) move power lower in the rev range.
I guess out there in the desert, you wouldn't want to go to a 50 rear sprocket.....
  • SID013
Posted November 05, 2006 - 04:05 PM
Hiya, When I want to play around with sprocket ratios I have a look at the [COLOR="Blue"]gearing calculator[/COLOR] spreadsheet on this website. I have found it great. :mad: http://www.4strokes.com/tech
Hope it helps.
Cheers from Oz.
  • griffithds
Posted November 06, 2006 - 06:08 PM
Hope it helps.
Cheers from Oz.
Great site! Thanks for the post.:mad: :mad: :worthy:
  • R_Little
Posted November 06, 2006 - 06:24 PM
The 444 kit on my wr400 is crazy fast!
  • Birdy426
Posted November 06, 2006 - 07:10 PM
Big bore makes lots more power, but the rev is a little slower. It still revs out, but it gets there a tad slower. I abso-freakin'-lutely love the power of my scooter with a 13.5:1 444 cc kit and Hot Cams intake and exhaust cams. The power isn't as "smooth" as a stock WR...it's got the bottom end of a WR, the mid-range hit of a YZ426, and revs out like no other. The only down side is the 13.5:1 piston requires race gas...
  • Alley Cat
Posted November 06, 2006 - 08:38 PM
That is a big point right there. I know JE pistons make a 13:1 for oversize bores, that might not require race gas. I went with a 12.8:1 (stock 12.3) for my bike for this exact reason.
  • wacker boy
Posted November 07, 2006 - 03:55 PM
Well guys thanks for your in put. I think i will go with the athena 478 big bore kit and a port job due to the fact i dont want to run race gas.Who would you guys recommand to do a good port job?
  • Birdy426
Posted November 07, 2006 - 09:41 PM
Eric Gorr's Forward Motion did mine. Great work. Engine Dynamics has a good rep as well.
  • Fullbore4
Posted November 18, 2006 - 10:48 PM
Intake
Is it worth it. I don't know yet! :cheers:
According to my Service Manual the stock intake cam has 8.65 mm lift.
  • MountainMax
Posted November 19, 2006 - 11:42 AM
Hehe, looks like about 2 HP over stock YZ, not as much as i thought, although it does hold it to a higher rpm....
