throttle response
2 replies to this topic
  • Allen
Posted January 15, 2001 - 04:36 AM
2000 wr
runs great untill it gets warm then the throttle response (low end) goes away. This just started out of the blue any suggestions?
  • James_Dean
Posted January 15, 2001 - 06:10 AM
Try adjusting the pilot (fuel) screw on the bottom of the float bowl. Write down how many turns out it is from all the way in for a reference. Turn it out from stock 1/4 turn at a time and check how it responds. If you get to 3 turns, try a bigger pilot jet back at 1 1/2 turns.
  • Allen
Posted January 15, 2001 - 11:14 AM
Dean thanks for the response.I tried what you said but it didn't work so i pulled the accelerator pump apart and found a broken pump spring.
thanks
allen
